Zum Hauptinhalt wechseln
Seville Classics MSC10166 Buttons Replacement
Was du brauchst
  1. Seville Classics MSC10166 Buttons Replacement, PCB (Printed Circuit Board): Schritt 1, Bild 1 von 1
    • Use the Phillips #2 screwdriver to remove the four 6 mm screws by unscrewing counterclockwise.
  2. Seville Classics MSC10166 Buttons Replacement: Schritt 2, Bild 1 von 1
    • Pull the front and back cover apart.
    • Be careful not to pull the front cover off completely. It holds the wires.
  3. Seville Classics MSC10166 Buttons Replacement: Schritt 3, Bild 1 von 1
    • Remove the Phillips 6 mm screw that holds the circuit board to the outer shell of the fan.
    • Shock warning: Make sure the fan is unplugged before removing the circuit board.
  4. Seville Classics MSC10166 Buttons Replacement: Schritt 4, Bild 1 von 1
    • Remove the top cover containing the circuit board and the wires by pulling it away from the outer shell of the fan.
  5. Seville Classics MSC10166 Buttons Replacement: Schritt 5, Bild 1 von 2 Seville Classics MSC10166 Buttons Replacement: Schritt 5, Bild 2 von 2
    • Remove the screws from the four corners of the circuit board.
    • Remove the circuit board from the top cover.
    • Do not touch the other side of the circuit board to avoid damaging the circuit elements.
  6. Seville Classics MSC10166 Buttons Replacement, Buttons: Schritt 6, Bild 1 von 1
    • Remove the two 8 mm screws that attach the buttons to the top cover of the fan.
  7. Seville Classics MSC10166 Buttons Replacement: Schritt 7, Bild 1 von 1
    • Remove the buttons from the top cover.
  8. Seville Classics MSC10166 Buttons Replacement: Schritt 8, Bild 1 von 1
    • Wipe down any dirt on the buttons.
  9. Seville Classics MSC10166 Buttons Replacement: Schritt 9, Bild 1 von 1
    • Wipe down the frame that holds the buttons.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Queena Phung
114 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 15-46, Forte Fall 2012 Mitglied von Cal Poly, Team 15-46, Forte Fall 2012
CPSU-FORTE-F12S15G46
5 Mitglieder
6 Anleitungen geschrieben
2 Kommentare
Great work but our problem is the micro switch itself, after exposing the circuit board I shorted the backside solder connections to cycle the fan on and off, everything works perfectly…..now I only need to know a part number so I can find a on/off micro switch.
any suggestions?
Thanks for any help you can provide
rickkingsbury@comcast.net
Rick - Antwort
Is there a way to keep the fan in ALWAYS ON position. So I can control it’s ON/OFF using a smart plug?
Vish Talreja - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 10
Letzte 30 Tage: 29
Insgesamt: 3,936
