Zum Hauptinhalt wechseln
Canon PowerShot SD1400 IS USB Port Replacement
Was du brauchst
  1. Canon PowerShot SD1400 IS USB Port Replacement, USB Port: Schritt 1, Bild 1 von 3 Canon PowerShot SD1400 IS USB Port Replacement, USB Port: Schritt 1, Bild 2 von 3 Canon PowerShot SD1400 IS USB Port Replacement, USB Port: Schritt 1, Bild 3 von 3
    • Remove the four 2mm Phillips #00 screws on both sides of the camera.
  2. Canon PowerShot SD1400 IS USB Port Replacement: Schritt 2, Bild 1 von 1
    • Remove the single 4mm Phillips #00 screw from the bottom.
  3. Canon PowerShot SD1400 IS USB Port Replacement: Schritt 3, Bild 1 von 1
    • Remove the front face panel off of the camera.
  4. Canon PowerShot SD1400 IS USB Port Replacement: Schritt 4, Bild 1 von 1
    • Remove the rear panel of the camera.
    • The user interface panel, side and bottom panel of the camera may fall down by itself while you are taking the rear panel of the camera.
  5. Canon PowerShot SD1400 IS USB Port Replacement: Schritt 5, Bild 1 von 1
    • Remove the 3mm Phillips #000 screw from the top of the camera.
  6. Canon PowerShot SD1400 IS USB Port Replacement: Schritt 6, Bild 1 von 1
    • Pry the golden ribbon cable from the motherboard with a plastic opening tool.
    • A screw will be visible underneath the golden ribbon after prying it.
  7. Canon PowerShot SD1400 IS USB Port Replacement: Schritt 7, Bild 1 von 1
    • Remove the 3mm Phillips #000 screw from the motherboard.
  8. Canon PowerShot SD1400 IS USB Port Replacement: Schritt 8, Bild 1 von 1
    • Use a plastic opening tool to flip up the retaining flap on the ribbon cable ZIF socket.
  9. Canon PowerShot SD1400 IS USB Port Replacement: Schritt 9, Bild 1 von 2 Canon PowerShot SD1400 IS USB Port Replacement: Schritt 9, Bild 2 von 2
    • Unplug the small chip from the face of the camera using a pair of tweezers.
  10. Canon PowerShot SD1400 IS USB Port Replacement: Schritt 10, Bild 1 von 1
    • Remove the 3mm Phillips #000 screw from the rear face of the camera.
  11. Canon PowerShot SD1400 IS USB Port Replacement: Schritt 11, Bild 1 von 1
    • Remove the top panel from the camera.
  12. Canon PowerShot SD1400 IS USB Port Replacement: Schritt 12, Bild 1 von 1
    • Pry the golden ribbon cable attached to the USB port using a plastic opening tool.
  13. Canon PowerShot SD1400 IS USB Port Replacement: Schritt 13, Bild 1 von 1
    • Remove the 3mm Phillips #000 screw located at the top right of the USB port.
  14. Canon PowerShot SD1400 IS USB Port Replacement: Schritt 14, Bild 1 von 2 Canon PowerShot SD1400 IS USB Port Replacement: Schritt 14, Bild 2 von 2
    • Remove the USB port.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Faris Rezwan
457 Reputation
2 Anleitungen geschrieben
IUPUI, Team S1-G2, Harley Spring 2018 Mitglied von IUPUI, Team S1-G2, Harley Spring 2018
IUPUI-HARLEY-S18S1G2
7 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 268
