Zum Hauptinhalt wechseln
Dell Inspiron 15 3559 Hard Drive Replacement
Was du brauchst
  1. Dell Inspiron 15 3559 Hard Drive Replacement, Remove the Screws: Schritt 1, Bild 1 von 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: Hard drives are fragile. Exercise care when handling the hard drive.
    • Remove the screws that secure the hard-drive assembly to the computer base.
  2. Dell Inspiron 15 3559 Hard Drive Replacement, Lifting the Latch: Schritt 2, Bild 1 von 2 Dell Inspiron 15 3559 Hard Drive Replacement, Lifting the Latch: Schritt 2, Bild 2 von 2
    • Lift the latch and disconnect the hard-drive cable from the system board.
  3. Dell Inspiron 15 3559 Hard Drive Replacement, Lifting the Hard-Drive Assembly: Schritt 3, Bild 1 von 1
    • Lift the hard-drive assembly off the computer base.
  4. Dell Inspiron 15 3559 Hard Drive Replacement, Disconnecting the Interposer: Schritt 4, Bild 1 von 1
    • Disconnect the interposer from the hard drive.
  5. Dell Inspiron 15 3559 Hard Drive Replacement, Remove the Screws: Schritt 5, Bild 1 von 1
    • Remove the screws that secure the hard-drive bracket to the hard drive and lift the hard-drive bracket off the hard drive.
  6. Dell Inspiron 15 3559 Hard Drive Replacement, Placing the Hard Drive: Schritt 6, Bild 1 von 2 Dell Inspiron 15 3559 Hard Drive Replacement, Placing the Hard Drive: Schritt 6, Bild 2 von 2
    • Place the hard-drive bracket over the NEW hard drive and align the screw holes on the hard-drive bracket with the screw holes on the hard drive.
  7. Dell Inspiron 15 3559 Hard Drive Replacement, Replace the Screws: Schritt 7, Bild 1 von 1
    • Replace the screws that secure the hard-drive bracket to the hard drive.
  8. Dell Inspiron 15 3559 Hard Drive Replacement, Sliding the Hard-Drive Assembly: Schritt 8, Bild 1 von 2 Dell Inspiron 15 3559 Hard Drive Replacement, Sliding the Hard-Drive Assembly: Schritt 8, Bild 2 von 2
    • Slide the hard-drive assembly in the computer base and align the screw holes on the hard-drive assembly with the screw holes on the computer base.
  9. Dell Inspiron 15 3559 Hard Drive Replacement, Replace the Screws: Schritt 9, Bild 1 von 1
    • Replace the screws that secure the hard-drive assembly to the computer base.
Ziellinie
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Terrence15
79.121 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.986 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 14
Insgesamt: 1,107
