Zum Hauptinhalt wechseln
Dell Inspiron 15 3565 Display Assembly Replacement
Was du brauchst
  1. Dell Inspiron 15 3565 Display Assembly Replacement, Remove the Screws: Schritt 1, Bild 1 von 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Remove the three screws (2.5x8) that secure the display hinges to the palm-rest assembly.
  2. Dell Inspiron 15 3565 Display Assembly Replacement, Open the Display Hinges: Schritt 2, Bild 1 von 1
    • Open the display hinges to an angle of 90 degrees.
  3. Dell Inspiron 15 3565 Display Assembly Replacement, Peeling the Tape: Schritt 3, Bild 1 von 1
    • Peel the tape that secures the display cable to the palm-rest assembly.
  4. Dell Inspiron 15 3565 Display Assembly Replacement, Open the Latch: Schritt 4, Bild 1 von 1
    • Open the latch and disconnect the display cable.
  5. Dell Inspiron 15 3565 Display Assembly Replacement, Open the Latch: Schritt 5, Bild 1 von 1
  6. Dell Inspiron 15 3565 Display Assembly Replacement, Note the Routing: Schritt 6, Bild 1 von 1
    • Note the display cable routing and remove the display cable from the routing guides on the palm-rest assembly.
  7. Dell Inspiron 15 3565 Display Assembly Replacement, Note the Antenna Cable: Schritt 7, Bild 1 von 1
    • Note the antenna cable routing and remove the cable from its routing guides on the palm-rest assembly.
  8. Dell Inspiron 15 3565 Display Assembly Replacement, Open the Palm-Rest Assembly: Schritt 8, Bild 1 von 1
    • Open the palm-rest assembly at an angle and slide it off the display assembly.
  9. Dell Inspiron 15 3565 Display Assembly Replacement, Placing the Display Assembly: Schritt 9, Bild 1 von 1
    • Place the NEW display assembly on a clean, flat surface.
  10. Dell Inspiron 15 3565 Display Assembly Replacement, Placing the Palm-Rest Assembly: Schritt 10, Bild 1 von 1
    • Place the palm-rest assembly on the display assembly.
  11. Dell Inspiron 15 3565 Display Assembly Replacement, Close the Hinges: Schritt 11, Bild 1 von 1
    • Close the display hinges and align the screw holes on the display hinges with the screw holes on the palm-rest assembly.
  12. Dell Inspiron 15 3565 Display Assembly Replacement, Replace the Screws: Schritt 12, Bild 1 von 1
    • Replace the three screws (2.5x8) that secure the display hinges to the palm-rest assembly.
  13. Dell Inspiron 15 3565 Display Assembly Replacement, Routing the Antenna Cables: Schritt 13, Bild 1 von 1
    • Route the antenna cables through the routing guides on the palm-rest assembly.
  14. Dell Inspiron 15 3565 Display Assembly Replacement, Connecting the Display Cable: Schritt 14, Bild 1 von 1
    • Connect the display cable and close the latch to secure the cable.
  15. Dell Inspiron 15 3565 Display Assembly Replacement, Route the Display Cable: Schritt 15, Bild 1 von 1
    • Route the display cable through the routing guides on the palm-rest assembly
  16. Dell Inspiron 15 3565 Display Assembly Replacement, Adhering the Tape: Schritt 16, Bild 1 von 1
    • Adhere the tape that secures the display cable to the palm-rest assembly.
    • Close the display and turn the computer over.
Ziellinie
Terrence15
79.121 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.986 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 13
Insgesamt: 828
