Zum Hauptinhalt wechseln
Dell Inspiron 15 5578 2-in-1 Memory Module Replacement
  1. Dell Inspiron 15 5578 2-in-1 Memory Module Replacement, Lifting the Mylar: Schritt 1, Bild 1 von 1
  2. Dell Inspiron 15 5578 2-in-1 Memory Module Replacement, Popping up the Memory Module: Schritt 2, Bild 1 von 3 Dell Inspiron 15 5578 2-in-1 Memory Module Replacement, Popping up the Memory Module: Schritt 2, Bild 2 von 3 Dell Inspiron 15 5578 2-in-1 Memory Module Replacement, Popping up the Memory Module: Schritt 2, Bild 3 von 3
    • Use your fingertips to carefully spread apart the securing-clips on each end of the memory-module slot until the memory module pops up.
  3. Dell Inspiron 15 5578 2-in-1 Memory Module Replacement, Remove the Memory Module: Schritt 3, Bild 1 von 2 Dell Inspiron 15 5578 2-in-1 Memory Module Replacement, Remove the Memory Module: Schritt 3, Bild 2 von 2
    • Remove the memory module from the memory-module slot.
  4. Dell Inspiron 15 5578 2-in-1 Memory Module Replacement, Lifting the Mylar: Schritt 4, Bild 1 von 2 Dell Inspiron 15 5578 2-in-1 Memory Module Replacement, Lifting the Mylar: Schritt 4, Bild 2 von 2
    • Lift the Mylar to access the memory-module slot.
  5. Dell Inspiron 15 5578 2-in-1 Memory Module Replacement, Align the Notch: Schritt 5, Bild 1 von 3 Dell Inspiron 15 5578 2-in-1 Memory Module Replacement, Align the Notch: Schritt 5, Bild 2 von 3 Dell Inspiron 15 5578 2-in-1 Memory Module Replacement, Align the Notch: Schritt 5, Bild 3 von 3
    • Align the notch on the memory module with the tab on the memory-module slot.
  6. Dell Inspiron 15 5578 2-in-1 Memory Module Replacement, Sliding the Memory Module: Schritt 6, Bild 1 von 1
    • Slide the memory module firmly into the slot at an angle and press the memory module down until it clicks into place.
    • NOTE: If you do not hear the click, remove the memory module and reinstall it.
Ziellinie
Terrence15
79.121 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 461
