Zum Hauptinhalt wechseln
Dell Inspiron 15 Gaming 7577 Hard Drive Replacement
Was du brauchst
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: Hard drives are fragile. Exercise care when handling the hard drive.
    • NOTE: The latch on the hard-drive locking connector is fragile. Pulling the latch forcefully may damage the hard-drive locking connector. Exercise care when handling the latch on the hard-drive locking connector.
  1. Dell Inspiron 15 Gaming 7577 Hard Drive Replacement, Disconnecting the Hard Drive Cable: Schritt 2, Bild 1 von 1
    • Open the latch and disconnect the hard-drive cable from the system board.
  2. Dell Inspiron 15 Gaming 7577 Hard Drive Replacement, Peeling the Hard Drive Cable: Schritt 3, Bild 1 von 1
    • Peel off the hard-drive cable from the computer base.
  3. Dell Inspiron 15 Gaming 7577 Hard Drive Replacement, Remove the Screws: Schritt 4, Bild 1 von 1
    • Remove the four screws (M2.5x3) that secure the hard-drive assembly to the computer base.
  4. Dell Inspiron 15 Gaming 7577 Hard Drive Replacement, Lifting the Hard-Drive Assembly: Schritt 5, Bild 1 von 1
    • Lift the hard-drive assembly, along with its cable, off the computer base.
  5. Dell Inspiron 15 Gaming 7577 Hard Drive Replacement, Disconnect the Inteposer: Schritt 6, Bild 1 von 1
    • Disconnect the interposer from the hard-drive assembly.
  6. Dell Inspiron 15 Gaming 7577 Hard Drive Replacement, Remove the Screws: Schritt 7, Bild 1 von 1
    • Remove the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
  7. Dell Inspiron 15 Gaming 7577 Hard Drive Replacement, Lifting the Hard Drive Bracket: Schritt 8, Bild 1 von 1
    • Lift the hard-drive bracket off the hard drive.
  8. Dell Inspiron 15 Gaming 7577 Hard Drive Replacement, Align the Screw Holes: Schritt 9, Bild 1 von 1
    • Align the screw holes on the hard-drive bracket with the screw holes on the NEW hard drive.
  9. Dell Inspiron 15 Gaming 7577 Hard Drive Replacement, Replace the Screws: Schritt 10, Bild 1 von 1
    • Replace the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
  10. Dell Inspiron 15 Gaming 7577 Hard Drive Replacement, Connect the Interposer: Schritt 11, Bild 1 von 1
    • Connect the interposer to the hard-drive assembly.
  11. Dell Inspiron 15 Gaming 7577 Hard Drive Replacement, Align the Screw Holes: Schritt 12, Bild 1 von 1
    • Align the screw holes on the hard-drive assembly with the screw holes on the computer base.
  12. Dell Inspiron 15 Gaming 7577 Hard Drive Replacement, Replace the Screws: Schritt 13, Bild 1 von 1
    • Replace the four screws (M2.5x3) that secure the hard-drive assembly to the computer base.
  13. Dell Inspiron 15 Gaming 7577 Hard Drive Replacement, Adhering the Hard Drive Cable: Schritt 14, Bild 1 von 1
    • Adhere the hard-drive cable to the computer base.
  14. Dell Inspiron 15 Gaming 7577 Hard Drive Replacement, Sliding the Hard Drive Cable: Schritt 15, Bild 1 von 1
    • Slide the hard-drive cable into the connector on the system board and close the latch to secure the hard-drive cable.
Ziellinie
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Terrence15
79.034 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 14
Insgesamt: 3,127
