Zum Hauptinhalt wechseln
Mitsubishi WD57734 Lamp Replacement
Was du brauchst
  1. Mitsubishi WD57734 Lamp Replacement, Lamp: Schritt 1, Bild 1 von 1
    • Before disassembling your television, be sure it is powered off and unplugged.
    • Remove the single 18 mm Phillips #1 screw on the lamp access panel.
  2. Mitsubishi WD57734 Lamp Replacement: Schritt 2, Bild 1 von 1
    • Pull the lamp access panel off of the back panel of the television by pulling straight back on the left side of the panel near the screw then pulling to the left.
  3. Mitsubishi WD57734 Lamp Replacement: Schritt 3, Bild 1 von 1
    • Loosen the two Phillips #2 screws securing the lamp housing to the television until the screws will swivel vertically.
    • These two screws are permanently attached to the lamp housing and cannot be removed completely.
  4. Mitsubishi WD57734 Lamp Replacement: Schritt 4, Bild 1 von 1
    • Using the handle, pull the lamp housing straight back out of the television.
    • Do not touch the glass of the lamp with your bare hands. The oil from your fingers can distort the TV image and lead to other issues.
Abschluss
Herman Chai
196 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 18-39, Regan Fall 2012 Mitglied von Cal Poly, Team 18-39, Regan Fall 2012
CPSU-REGAN-F12S18G39
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 12
Insgesamt: 2,176
