Einleitung
If your back case is cracked or broken this guide will show you how it is removed and replaced.
Was du brauchst
Remove the battery cover.
Remove the AAA batteries from the calculator.
Remove the 5mm Philips #00 screw holding backup battery cover.
Remove the backup battery cover.
Use plastic opening tool to remove the backup battery. Place the tool in the small cut-out next to the battery and pry the battery out.
Unscrew the six 7.5mm T6 screws on the back case. You will need to use a screwdriver with a long and skinny head.
Pry back case off. Insert the plastic opening tool in the track for the protective cover and pry the halves of the case apart.
8 weitere Nutzer:innen haben diese Anleitung absolviert.
