Zum Hauptinhalt wechseln
Dell Inspiron 15R 5521 Hard-Drive Assembly Replacement
Was du brauchst
  1. Dell Inspiron 15R 5521 Hard-Drive Assembly Replacement, Remove the Screws: Schritt 1, Bild 1 von 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin".
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
    • Remove the screws that secure the hard-drive assembly to the computer base.
  2. Dell Inspiron 15R 5521 Hard-Drive Assembly Replacement, Sliding the Hard-Drive Assembly: Schritt 2, Bild 1 von 1
    • Slide the hard-drive assembly forward to disconnect the hard-drive assembly from the system board.
  3. Dell Inspiron 15R 5521 Hard-Drive Assembly Replacement, Lifting the Hard Drive Assembly: Schritt 3, Bild 1 von 1
    • Using the pull-tab, lift the hard-drive assembly out of the computer base.
  4. Dell Inspiron 15R 5521 Hard-Drive Assembly Replacement, Remove the Screws: Schritt 4, Bild 1 von 1
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  5. Dell Inspiron 15R 5521 Hard-Drive Assembly Replacement, Lifting the Hard Drive Bracket: Schritt 5, Bild 1 von 1
    • Lift the hard-drive bracket off the hard drive.
  6. Dell Inspiron 15R 5521 Hard-Drive Assembly Replacement, Align the Screw Holes: Schritt 6, Bild 1 von 1
    • Align the screw holes on the hard-drive bracket with the screw holes on the NEW hard drive.
  7. Dell Inspiron 15R 5521 Hard-Drive Assembly Replacement, Replace the Screws: Schritt 7, Bild 1 von 1
    • Replace the screws that secure the hard-drive bracket to the hard drive.
  8. Dell Inspiron 15R 5521 Hard-Drive Assembly Replacement, Sliding the Assembly: Schritt 8, Bild 1 von 1
    • Slide and place the hard-drive assembly in the hard-drive bay.
  9. Dell Inspiron 15R 5521 Hard-Drive Assembly Replacement, Sliding the Assembly: Schritt 9, Bild 1 von 1
    • Slide the hard-drive assembly backward to connect the hard-drive assembly to the system board.
  10. Dell Inspiron 15R 5521 Hard-Drive Assembly Replacement, Replace the Screws: Schritt 10, Bild 1 von 1
    • Replace the screws that secure the hard-drive assembly to the computer base.
Ziellinie
Terrence15
79.131 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.986 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 12
Insgesamt: 881
