Zum Hauptinhalt wechseln
Was du brauchst
Einführungsvideo
Dieser Teardown ist keine Reparaturanleitung. Um dein Dell XPS 15 9570 zu reparieren, verwende unsere Fehlerbehebungsseite.
    • Here's an unboxing of the device, followed by how to remove the battery and RAM from your 9570.
IT FIX
6.340 Reputation
74 Anleitungen geschrieben
5 Kommentare
nice! if I have the fhd version of xps 15 9570, with 2X4gb ddr4 and 256ssd is it possible to change the battery from 56wh to 97wh?
orit2408 - Antwort
Hm, good question, interesting which configuration you have, if it’s the same as mine so this is not a problem
IT FIX -
As far as I know that one has an option for an HDD, which uses up space where the 97wh is supposed to be.
Dennis van der Stelt -
I buyed directly from Dell the 97whr (product code 5XJ28 / GPM03 ) for my FHD 9570. I replaced without issues my 56wh removing the second hard drive box. Total cost: 76,58€ + 30,00€ shipping to Italy .
Massimiliano Monaro - Antwort
Hi. Do you still have the old battery 56whr? Do you want sell it? I’m interested.
kurumadeiku@gmail.com
Jarek Musia -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 10
Letzte 30 Tage: 36
Insgesamt: 23,380
