Zum Hauptinhalt wechseln
Fix: makecab.exe runs for 5-10 minutes after every startup
  1. Fix: makecab.exe runs for 5-10 minutes after every startup, Find CBS log files folder: Schritt 1, Bild 1 von 1
    • Find CBS log files folder. The folder usually contains a .log file under 2 GB, and some .cab files.
  2. Fix: makecab.exe runs for 5-10 minutes after every startup, Remove any .log files larger than 2 GB: Schritt 2, Bild 1 von 2 Fix: makecab.exe runs for 5-10 minutes after every startup, Remove any .log files larger than 2 GB: Schritt 2, Bild 2 von 2
    • Delete, or move away if you want to keep the logs, any .log files larger than 2 GB in the CBS folder.
    • If makecab.exe is currently running and processing the log files, you may need to end it through Task manager.
Ziellinie
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Somnic
195 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 12
Insgesamt: 842
