Zum Hauptinhalt wechseln
Uwell Crown III Coil Replacement
Was du brauchst
  1. Uwell Crown III Coil Replacement, Coil: Schritt 1, Bild 1 von 3 Uwell Crown III Coil Replacement, Coil: Schritt 1, Bild 2 von 3 Uwell Crown III Coil Replacement, Coil: Schritt 1, Bild 3 von 3
    • Remove the tank from the E-cigarette by gently unscrewing it by hand.
  2. Uwell Crown III Coil Replacement: Schritt 2, Bild 1 von 3 Uwell Crown III Coil Replacement: Schritt 2, Bild 2 von 3 Uwell Crown III Coil Replacement: Schritt 2, Bild 3 von 3
    • Take-off the upper lid. This is necessary as the lid will go through cleaning process.
  3. Uwell Crown III Coil Replacement: Schritt 3, Bild 1 von 2 Uwell Crown III Coil Replacement: Schritt 3, Bild 2 von 2
    • Remove the bottom lid from the tank. The bottom lid holds the coil inside the tank. By removing the bottom lid, you are able to take out the coil.
  4. Uwell Crown III Coil Replacement: Schritt 4, Bild 1 von 3 Uwell Crown III Coil Replacement: Schritt 4, Bild 2 von 3 Uwell Crown III Coil Replacement: Schritt 4, Bild 3 von 3
    • Remove the old coil from the tank.
    • In the third picture, you can see the difference between the new coil on the left and the burnt coil on the right.
  5. Uwell Crown III Coil Replacement: Schritt 5, Bild 1 von 1
    • This is the tank and both upper and bottom lids after the disassembly process.
  6. Uwell Crown III Coil Replacement: Schritt 6, Bild 1 von 2 Uwell Crown III Coil Replacement: Schritt 6, Bild 2 von 2
    • To clean the tank and the lids, you need to submerge them in a glass of water for approximately 3-4 minutes to make sure they are cleaned properly.
  7. Uwell Crown III Coil Replacement: Schritt 7, Bild 1 von 3 Uwell Crown III Coil Replacement: Schritt 7, Bild 2 von 3 Uwell Crown III Coil Replacement: Schritt 7, Bild 3 von 3
    • After the tank and the lids are cleaned, use the towel to dry them as much possible before the next step.
  8. Uwell Crown III Coil Replacement: Schritt 8, Bild 1 von 1
    • Use the hair dryer with medium heat to make sure no water drops exist.
    • Any water drops might affect the function of the coil which will result into a flavor change.
  9. Uwell Crown III Coil Replacement: Schritt 9, Bild 1 von 3 Uwell Crown III Coil Replacement: Schritt 9, Bild 2 von 3 Uwell Crown III Coil Replacement: Schritt 9, Bild 3 von 3
    • Place the new coil inside the tank. Make sure the coil is stable and not moving.
    • Using the two lids, close the tank from both sides and make sure that the lids are perfectly sealed.
Abschluss
To reassemble your device, follow step 2 in reverse order.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Washington State, Team S1-G1, Hope Summer 2018 Mitglied von Washington State, Team S1-G1, Hope Summer 2018
WSU-HOPE-SU18S1G1
3 Mitglieder
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 11
Letzte 30 Tage: 35
Insgesamt: 5,508
