Einleitung
This guide will show you how to test and replace a faulty switch on a Revlon 473 Hair Dryer.
A faulty switch not only limits operation, but it is also a fire hazard. If the power switch on your Revlon 473 Hair Dryer isn't functioning, a switch replacement can improve the operation and safety of the unit.
Disconnect the Revlon 473 from any power source before you begin this repair.
Was du brauchst
Separate the shell from the main component.
Check to ensure each piece is free from debris.
Bring the probes toward each switch to test for continuity.
If the numbers on the multimeter continue to change, the circuit is closed and the switches are functioning.
If the meter stays at a set number, the circuit is open, and the switch needs to be replaced.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
