Zum Hauptinhalt wechseln
Repairing Quasar Microwave Fan
Was du brauchst
  1. Repairing Quasar Microwave Fan, Disassembling Quasar Microwave Outer Cover: Schritt 1, Bild 1 von 1
    • Disconnect the power supply cord from the outlet.
  2. Repairing Quasar Microwave Fan: Schritt 2, Bild 1 von 2 Repairing Quasar Microwave Fan: Schritt 2, Bild 2 von 2
    • Remove the eight screws holding the wood-patterned cover to the microwave frame.
    • The first four screws are located on either side of the microwave front.
  3. Repairing Quasar Microwave Fan: Schritt 3, Bild 1 von 2 Repairing Quasar Microwave Fan: Schritt 3, Bild 2 von 2
    • Remove the additional four screws securing the wood-paneled case to the microwave frame.
  4. Repairing Quasar Microwave Fan: Schritt 4, Bild 1 von 3 Repairing Quasar Microwave Fan: Schritt 4, Bild 2 von 3 Repairing Quasar Microwave Fan: Schritt 4, Bild 3 von 3
    • Placing your hands on either side of the case, slide the case back gently until you feel it completely separate from the microwave frame.
    • Lift the case upward slowly until the case is free of the microwave.
  5. Repairing Quasar Microwave Fan, Repairing Quasar Microwave Fan: Schritt 5, Bild 1 von 2 Repairing Quasar Microwave Fan, Repairing Quasar Microwave Fan: Schritt 5, Bild 2 von 2
    • Locate the fan in the newly exposed interior.
    • Try spinning the fan with your finger. If it spins freely, the fan is not jammed.
    • If the fan does not spin freely, locate what is jamming the fan and remove it.
  6. Repairing Quasar Microwave Fan: Schritt 6, Bild 1 von 1
    • If the fan is not jammed yet still does not work, check that there are no disconnected wires, especially to the fan.
    • In order to work properly, there should be two wires going in and out of the fan. If you are missing either of these wires, locate the loose wire/s and connect them.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Melanie
107 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 2-12, Propen Fall 2012 Mitglied von Cal Poly, Team 2-12, Propen Fall 2012
CPSU-PROPEN-F12S2G12
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 7
Insgesamt: 1,502
