Einleitung
Use this guide to replace a faulty interconnect board.
Was du brauchst
Power down your Mac mini, disconnect all of the cables, and flip it over.
Insert the Jimmy into the crack between the aluminum top housing and the plastic lower housing.
The Jimmy should reach a stop about 3/8" down.
Gently bend the Jimmy outwards to pry the crack open a little larger and lift the lower housing up a small amount.
Once you have the first side free, rotate the Mac mini and start prying up on the front edge.
Use the same prying motion to both bend the clips inward and lift the lower housing up out of the top housing.
You may need to move the Jimmy along the edge to pry up all of the clips. Be patient and do a little bit at a time.
Slightly squeeze the two retaining arms toward each other and lift the AirPort antenna off its post.
Use the tip of a spudger to slightly lift the left side of the ZIF cable lock up from its socket.
Remove the recessed Phillips screw near the power button securing the internal frame to the bottom housing.
Remove the recessed Phillips screw near the sleep light securing the internal frame to the bottom housing.
Remove the Phillips screw near the audio ports securing the internal frame to the bottom case.
Gently lift the internal frame up from the bottom housing, minding the AirPort antenna and any other cables that may get caught.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Disconnect the following connectors from the interconnect board:
Bluetooth cable.
IR board cable.
Fan cable.
Remove the two Phillips screws securing the interconnect board to the optical drive.
Use the flat end of a spudger to separate the interconnect board from the optical and hard drives.
Remove the interconnect board from the internal frame.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
