Zum Hauptinhalt wechseln
Nook Tablet Speaker Assembly Replacement
Was du brauchst
  1. Nook Tablet Speaker Assembly Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Flip the Nook over.
  2. Nook Tablet Speaker Assembly Replacement: Schritt 2, Bild 1 von 2 Nook Tablet Speaker Assembly Replacement: Schritt 2, Bild 2 von 2
    • Lift the flap that reads "Nook" to reveal the tape that is underneath. Remove the memory card if one is present.
    • Remove the tape covering the round holes to reveal two T5 Torx screws.
    • Remove the two T5 Torx screws securing the back cover.
  3. Nook Tablet Speaker Assembly Replacement: Schritt 3, Bild 1 von 2 Nook Tablet Speaker Assembly Replacement: Schritt 3, Bild 2 von 2
    • Insert the flat end of a spudger between the front panel and the rear assembly.
    • Though these photos show a screwdriver, use a spudger or plastic opening tool in order to prevent damage to the device.
    • Use a spudger to lift the the back panel from the rest of the Nook.
  4. Nook Tablet Speaker Assembly Replacement: Schritt 4, Bild 1 von 2 Nook Tablet Speaker Assembly Replacement: Schritt 4, Bild 2 von 2
    • Slide the spudger around the edges of the Nook to loosen the back panel.
  5. Nook Tablet Speaker Assembly Replacement: Schritt 5, Bild 1 von 1
    • Pull the back panel off the Nook.
  6. Nook Tablet Speaker Assembly Replacement, Screen Bezel: Schritt 6, Bild 1 von 2 Nook Tablet Speaker Assembly Replacement, Screen Bezel: Schritt 6, Bild 2 von 2
    • Using the T5 Torx screwdriver, remove the ten T5 screws from around the edges of the silver midframe.
  7. Nook Tablet Speaker Assembly Replacement: Schritt 7, Bild 1 von 2 Nook Tablet Speaker Assembly Replacement: Schritt 7, Bild 2 von 2
    • Using a spudger or plastic opening tool, carefully pry the screen bezel away from the silver midframe.
  8. Nook Tablet Speaker Assembly Replacement, Disconnect the Battery: Schritt 8, Bild 1 von 2 Nook Tablet Speaker Assembly Replacement, Disconnect the Battery: Schritt 8, Bild 2 von 2
    • Lift up the foam pad at the corner of the battery to reveal the battery connector.
    • Use a spudger or plastic opening tool to disconnect the battery cable from the motherboard.
    • These photos show a screwdriver, but we recommend using a nonconductive tool like a spudger to prevent a potential short.
  9. Nook Tablet Speaker Assembly Replacement, Midframe: Schritt 9, Bild 1 von 1
    • Lift up the foam that covers the power connector and volume connector.
    • Disconnect the power and volume cables from their sockets on the motherboard.
  10. Nook Tablet Speaker Assembly Replacement: Schritt 10, Bild 1 von 2 Nook Tablet Speaker Assembly Replacement: Schritt 10, Bild 2 von 2
    • Carefully lift the silver midframe away from the motherboard and display assembly.
    • Be careful when handling the motherboard, making sure to not dislodge/shift any of its major components.
  11. Nook Tablet Speaker Assembly Replacement, Removing Speaker Assembly: Schritt 11, Bild 1 von 1
    • Using your hands pull the square speaker assembly component off the motherboard.
  12. Nook Tablet Speaker Assembly Replacement, Replacing Speaker Assembly: Schritt 12, Bild 1 von 1
    • Now place the new speaker assembly component back in the same square location.
    • As Step 12 mentions, make sure to realign the speaker assembly correctly in the square.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Josh Fisher
9 Reputation
1 Anleitung geschrieben
Cal Poly, Team 1-4, Propen Fall 2012 Mitglied von Cal Poly, Team 1-4, Propen Fall 2012
CPSU-PROPEN-F12S1G4
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 13
Insgesamt: 2,102
