Zum Hauptinhalt wechseln
Sprinkler Head Replacement
Was du brauchst
  1. Sprinkler Head Replacement, Sprinkler Head: Schritt 1, Bild 1 von 1
    • Turn off the water supply to the sprinklers.
    • This process will vary depending on your sprinkler controller.
  2. Sprinkler Head Replacement: Schritt 2, Bild 1 von 1
    • Find where the water supply feeds the sprinkler system and close the valve in the event of emergency or unforeseen circumstances.
  3. Sprinkler Head Replacement: Schritt 3, Bild 1 von 1
    • Dig a hole down to the base of the sprinkler head.
    • Be careful to avoid puncturing the sprinkler line.
  4. Sprinkler Head Replacement: Schritt 4, Bild 1 von 1
    • Using your hand or a gardening trowel, finish digging so that the sprinkler head is fully visible and is clear of dirt and debris.
  5. Sprinkler Head Replacement: Schritt 5, Bild 1 von 2 Sprinkler Head Replacement: Schritt 5, Bild 2 von 2
    • Unscrew the sprinkler head from the line it is attached to.
    • If is loose enough you may not need pliers.
  6. Sprinkler Head Replacement: Schritt 6, Bild 1 von 2 Sprinkler Head Replacement: Schritt 6, Bild 2 von 2
    • Coat the threads of the water line with teflon tape to avoid leaking.
  7. Sprinkler Head Replacement: Schritt 7, Bild 1 von 2 Sprinkler Head Replacement: Schritt 7, Bild 2 von 2
    • Using your hand, screw the new sprinkler head on over the teflon tape.
    • Once the sprinkler head is hand tight, use pliers to tighten it by another half turn.
  8. Sprinkler Head Replacement: Schritt 8, Bild 1 von 1
    • Fill the hole in and pack it down to avoid unwanted movement of the new sprinkler head.
  9. Sprinkler Head Replacement: Schritt 9, Bild 1 von 1
    • Turn the sprinkler system on.
  10. Sprinkler Head Replacement: Schritt 10, Bild 1 von 1
    • Twist the top of the sprinkler until it is aimed where you want it.
  11. Sprinkler Head Replacement: Schritt 11, Bild 1 von 1
    • Use a flat head screwdriver to adjust the flow of water if needed.
    • Turning right decreases the water flow. Turning left increases the water flow.
Abschluss
Enjoy your green lawn and water savings.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 24
Insgesamt: 378
