Zum Hauptinhalt wechseln
Samsung Galaxy Amp 2 Home Button Replacement
Was du brauchst
  1. Samsung Galaxy Amp 2 Home Button Replacement, Battery: Schritt 1, Bild 1 von 2 Samsung Galaxy Amp 2 Home Button Replacement, Battery: Schritt 1, Bild 2 von 2
    • Insert your fingernail or an opening tool into the divot on the side of the phone. The divot is located to the left of the rear-facing camera.
    • Lift upwards and gently pry the rear panel off of the phone.
  2. Samsung Galaxy Amp 2 Home Button Replacement: Schritt 2, Bild 1 von 3 Samsung Galaxy Amp 2 Home Button Replacement: Schritt 2, Bild 2 von 3 Samsung Galaxy Amp 2 Home Button Replacement: Schritt 2, Bild 3 von 3
    • Insert a fingernail or plastic opening tool into the gap in the bottom right corner of the battery and lift upward.
    • Grip the battery and safely remove it from the phone.
  3. Samsung Galaxy Amp 2 Home Button Replacement, Screen: Schritt 3, Bild 1 von 3 Samsung Galaxy Amp 2 Home Button Replacement, Screen: Schritt 3, Bild 2 von 3 Samsung Galaxy Amp 2 Home Button Replacement, Screen: Schritt 3, Bild 3 von 3
    • Using angled tweezers, lift the small rectangular guard at upper right corner of the phone.
    • Disconnect the connector piece from the back panel.
  4. Samsung Galaxy Amp 2 Home Button Replacement: Schritt 4, Bild 1 von 1
    • Apply heat from heat gun or blow dryer on periphery of the screen for one to two minutes.
  5. Samsung Galaxy Amp 2 Home Button Replacement: Schritt 5, Bild 1 von 3 Samsung Galaxy Amp 2 Home Button Replacement: Schritt 5, Bild 2 von 3 Samsung Galaxy Amp 2 Home Button Replacement: Schritt 5, Bild 3 von 3
    • Use four plastic opening tools to gently pry off the screen.
    • Optional: Use a suction tool to pull the screen off.
  6. Samsung Galaxy Amp 2 Home Button Replacement, Motherboard: Schritt 6, Bild 1 von 3 Samsung Galaxy Amp 2 Home Button Replacement, Motherboard: Schritt 6, Bild 2 von 3 Samsung Galaxy Amp 2 Home Button Replacement, Motherboard: Schritt 6, Bild 3 von 3
    • Unscrew the nine 4.5mm PH screws using a screwdriver with a PH000 bit.
    • Push from the back panel to remove the bottom part of the motherboard.
    • Push from the front panel to remove the top part of the motherboard.
  7. Samsung Galaxy Amp 2 Home Button Replacement, Home Button: Schritt 7, Bild 1 von 3 Samsung Galaxy Amp 2 Home Button Replacement, Home Button: Schritt 7, Bild 2 von 3 Samsung Galaxy Amp 2 Home Button Replacement, Home Button: Schritt 7, Bild 3 von 3
    • Pull the black tab that is located on the bottom of the motherboard.
    • Push the home button out of the black tab.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
UW Tacoma, Team S1-G1, Cardinal Summer 2018 Mitglied von UW Tacoma, Team S1-G1, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G1
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 10
Insgesamt: 467
