Zum Hauptinhalt wechseln
Panasonic KX-T4000R Cordless Phone Antenna Replacement
Was du brauchst
  1. Panasonic KX-T4000R Cordless Phone Antenna Replacement, Removing the Back Panel: Schritt 1, Bild 1 von 2 Panasonic KX-T4000R Cordless Phone Antenna Replacement, Removing the Back Panel: Schritt 1, Bild 2 von 2
    • Orient the phone so that the phone model and other descriptive information is facing upward.
    • Locate the two silver screws near the hinge where the battery is housed.
    • Remove the silver screws using a Phillips head #2 screwdriver.
  2. Panasonic KX-T4000R Cordless Phone Antenna Replacement: Schritt 2, Bild 1 von 3 Panasonic KX-T4000R Cordless Phone Antenna Replacement: Schritt 2, Bild 2 von 3 Panasonic KX-T4000R Cordless Phone Antenna Replacement: Schritt 2, Bild 3 von 3
    • Pull off the back panel of the phone.
    • Make sure you pull the cover off carefully in order to prevent damage to the back cover.
  3. Panasonic KX-T4000R Cordless Phone Antenna Replacement, Antenna: Schritt 3, Bild 1 von 2 Panasonic KX-T4000R Cordless Phone Antenna Replacement, Antenna: Schritt 3, Bild 2 von 2
    • Find the silver screw located in the red circle.
    • Using a Philips head #2 screwdriver, remove the screw holding the antenna in place.
  4. Panasonic KX-T4000R Cordless Phone Antenna Replacement: Schritt 4, Bild 1 von 2 Panasonic KX-T4000R Cordless Phone Antenna Replacement: Schritt 4, Bild 2 von 2
    • Press the release button.
    • The release button is located in the red circle in the image to the left.
Abschluss
Clemson, Team 15-1, Benson Fall 2012 Mitglied von Clemson, Team 15-1, Benson Fall 2012
CLEM-BENSON-F12S15G1
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 1,857
