Zum Hauptinhalt wechseln
Lenovo N20p Chromebook WLAN & Bluetooth Replacement
Was du brauchst
  1. Lenovo N20p Chromebook WLAN & Bluetooth Replacement, Keyboard: Schritt 1, Bild 1 von 2 Lenovo N20p Chromebook WLAN & Bluetooth Replacement, Keyboard: Schritt 1, Bild 2 von 2
    • Power down the Chromebook before starting any repair.
    • Remove the two 3.5 mm Phillips #0 screws using a screwdriver.
    • It is only necessary to remove these two screws to complete this step.
  2. Lenovo N20p Chromebook WLAN & Bluetooth Replacement: Schritt 2, Bild 1 von 2 Lenovo N20p Chromebook WLAN & Bluetooth Replacement: Schritt 2, Bild 2 von 2
    • Use the hook of the metal spudger to carefully lift up the keyboard.
    • Lift the keyboard carefully. If you lift too quickly, it might break the two cables that connect the keyboard to the motherboard.
  3. Lenovo N20p Chromebook WLAN & Bluetooth Replacement: Schritt 3, Bild 1 von 3 Lenovo N20p Chromebook WLAN & Bluetooth Replacement: Schritt 3, Bild 2 von 3 Lenovo N20p Chromebook WLAN & Bluetooth Replacement: Schritt 3, Bild 3 von 3
    • Carefully, disconnect the keyboard cable from the motherboard carefully by pulling on the blue tab of the cable.
    • You will now be able to replace the keyboard.
  4. Lenovo N20p Chromebook WLAN & Bluetooth Replacement, Battery: Schritt 4, Bild 1 von 3 Lenovo N20p Chromebook WLAN & Bluetooth Replacement, Battery: Schritt 4, Bild 2 von 3 Lenovo N20p Chromebook WLAN & Bluetooth Replacement, Battery: Schritt 4, Bild 3 von 3
    • Remove the two rubber feet of the back of the Chromebook using a metal spudger.
    • Remove six bottom 3.5 mm Phillips #0 screws and two top 5 mm Phillips #1 screws.
  5. Lenovo N20p Chromebook WLAN & Bluetooth Replacement: Schritt 5, Bild 1 von 1
    • Remove all nine 3.5 mm Phillips #00 screws using a screwdriver.
  6. Lenovo N20p Chromebook WLAN & Bluetooth Replacement: Schritt 6, Bild 1 von 2 Lenovo N20p Chromebook WLAN & Bluetooth Replacement: Schritt 6, Bild 2 von 2
    • Disconnect the battery cable from the motherboard.
    • Disconnect the touch-pad cable from the motherboard.
  7. Lenovo N20p Chromebook WLAN & Bluetooth Replacement: Schritt 7, Bild 1 von 2 Lenovo N20p Chromebook WLAN & Bluetooth Replacement: Schritt 7, Bild 2 von 2
    • Use the metal spudger along the seam between the keyboard and the bottom of the Chromebook to lift up and remove the palm rest assembly.
    • It is normal for it to click loudly when it is released. Corner tags will be harder to release than other tags and will make a loud sound.
  8. Lenovo N20p Chromebook WLAN & Bluetooth Replacement: Schritt 8, Bild 1 von 3 Lenovo N20p Chromebook WLAN & Bluetooth Replacement: Schritt 8, Bild 2 von 3 Lenovo N20p Chromebook WLAN & Bluetooth Replacement: Schritt 8, Bild 3 von 3
    • Disconnect the USB cable from the motherboard by pulling the blue tab out of the cable.
    • Remove all five 3.0 mm Phillips #00 screws which connect the battery and motherboard.
  9. Lenovo N20p Chromebook WLAN & Bluetooth Replacement: Schritt 9, Bild 1 von 2 Lenovo N20p Chromebook WLAN & Bluetooth Replacement: Schritt 9, Bild 2 von 2
    • Remove the battery.
    • It is helpful to lift and hold the battery as shown.
  10. Lenovo N20p Chromebook WLAN & Bluetooth Replacement, WLAN & Bluetooth: Schritt 10, Bild 1 von 3 Lenovo N20p Chromebook WLAN & Bluetooth Replacement, WLAN & Bluetooth: Schritt 10, Bild 2 von 3 Lenovo N20p Chromebook WLAN & Bluetooth Replacement, WLAN & Bluetooth: Schritt 10, Bild 3 von 3
    • Disconnect the white and black cables from the WLAN & Bluetooth combo.
    • Remove the 2 mm Phillips #1 screw.
    • Lift and pull the WLAN & Bluetooth in the direction shown.
  11. Lenovo N20p Chromebook WLAN & Bluetooth Replacement: Schritt 11, Bild 1 von 1
    • You will now be able to replace the WLAN & Bluetooth combo module.
Abschluss
Shihao Cao
497 Reputation
4 Anleitungen geschrieben
UW Tacoma, Team S1-G2, Cardinal Summer 2018 Mitglied von UW Tacoma, Team S1-G2, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G2
3 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 5
Insgesamt: 201
