Zum Hauptinhalt wechseln
Lorex A-MPX IR Bullet Camera Disassembly
Was du brauchst
  1. Lorex  A-MPX IR Bullet Camera Disassembly, Quick look: Schritt 1, Bild 1 von 2 Lorex  A-MPX IR Bullet Camera Disassembly, Quick look: Schritt 1, Bild 2 von 2
    • This little camera comes with the LHA4000 kit by Lorex.
    • It has a 4K sensor with motion sensor and infrared lights
  2. Lorex  A-MPX IR Bullet Camera Disassembly, Removing the lense: Schritt 2, Bild 1 von 2 Lorex  A-MPX IR Bullet Camera Disassembly, Removing the lense: Schritt 2, Bild 2 von 2
    • Remove the 4 screws holding down the camera lens. They are standard Philipps #1
    • Be careful not to pull the sensor as it is still attached to the signal cables.
  3. Lorex  A-MPX IR Bullet Camera Disassembly, Camera Sensor: Schritt 3, Bild 1 von 3 Lorex  A-MPX IR Bullet Camera Disassembly, Camera Sensor: Schritt 3, Bild 2 von 3 Lorex  A-MPX IR Bullet Camera Disassembly, Camera Sensor: Schritt 3, Bild 3 von 3
    • The system board is directly attached to the back of the lens.
    • The connector is a simple 4 wires. This make it very easy to repair.
  4. Lorex  A-MPX IR Bullet Camera Disassembly, Outer casing: Schritt 4, Bild 1 von 3 Lorex  A-MPX IR Bullet Camera Disassembly, Outer casing: Schritt 4, Bild 2 von 3 Lorex  A-MPX IR Bullet Camera Disassembly, Outer casing: Schritt 4, Bild 3 von 3
    • There is a rubber grommet that keep moisture away from the inside of the board.
    • There IS also this sillica pack inside the camera if moisture ever breach in.
    • The base is fixed to the feet using a single Phillips #1 screw
    • In order to separate the camera from the feet, you will need to undo the connector. The wires are thin so be careful.
  5. Lorex  A-MPX IR Bullet Camera Disassembly, Whole assembly: Schritt 5, Bild 1 von 1
    • Very simple design for a very simple device. The whole assembly is held by 6 screws. Making it very easy to re-assemble.
Abschluss
Hans
1.920 Reputation
6 Anleitungen geschrieben
Mero IT Services Mitglied von Mero IT Services
Business
1 Mitglied
3 Kommentare
Can you do disassembly video on Lorex C861MB camera ?
Mark Curry - Antwort
Can you do a disassembly video on Lorex C861MB camera ?
How much is this camera
Michael Teeter - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 17
Letzte 30 Tage: 39
Insgesamt: 2,531
