Zum Hauptinhalt wechseln
IBM ThinkPad T30 Hard Drive Replacement
Was du brauchst
  1. IBM ThinkPad T30 Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 3 IBM ThinkPad T30 Hard Drive Replacement, Battery: Schritt 1, Bild 2 von 3 IBM ThinkPad T30 Hard Drive Replacement, Battery: Schritt 1, Bild 3 von 3
    • Make sure the ThinkPad is off and the power supply is unplugged.
    • Flip the ThinkPad upside down with the bottom facing you.
    • Slide the latch to the right into the unlock position.
    • While holding the latch in the unlock position, lift the battery out with your other hand.
  2. IBM ThinkPad T30 Hard Drive Replacement, Hard Drive: Schritt 2, Bild 1 von 1
    • Flip to the back of the Thinkpad.
    • Remove the single 11 mm screw using the Phillips #0 screwdriver.
  3. IBM ThinkPad T30 Hard Drive Replacement: Schritt 3, Bild 1 von 3 IBM ThinkPad T30 Hard Drive Replacement: Schritt 3, Bild 2 von 3 IBM ThinkPad T30 Hard Drive Replacement: Schritt 3, Bild 3 von 3
    • Flip the Thinkpad on its side to get a better view of the hard drive.
    • Push on the lower edge of the hard drive cover to detach the hard drive from the Thinkpad.
    • Once you have detached the hard drive from the Thinkpad, slide the hard drive out of the device.
  4. IBM ThinkPad T30 Hard Drive Replacement: Schritt 4, Bild 1 von 2 IBM ThinkPad T30 Hard Drive Replacement: Schritt 4, Bild 2 von 2
    • Using the plastic tool, remove the black plastic cover from the main body of the hard drive.
    • Place the plastic tool at the ends of the plastic cover to detach it from the hard drive.
    • Once the black plastic has been detached, the plastic will then slide off the body of the hard drive.
  5. IBM ThinkPad T30 Hard Drive Replacement: Schritt 5, Bild 1 von 2 IBM ThinkPad T30 Hard Drive Replacement: Schritt 5, Bild 2 von 2
    • Remove the four 2.8 mm screws from the mounting bracket using a Phillips #0 screwdriver.
    • Pull the mounting bracket off of the hard drive.
    • It may be easier to remove the mounting bracket by rotating it off of the hard drive as if it is on a hinge.
Abschluss
To reassemble your device with a new hard drive, follow these instructions in reverse order with a new hard drive replacing the old one.
11 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 3-20, Amido Fall 2012 Mitglied von Cal Poly, Team 3-20, Amido Fall 2012
CPSU-AMIDO-F12S3G20
3 Mitglieder
16 Anleitungen geschrieben
Ein Kommentar
good description and photos..thanks :]
David - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 12
Letzte 30 Tage: 60
Insgesamt: 19,028
