Zum Hauptinhalt wechseln
Trek 820 Tail Light Mounting Bracket Replacement
Was du brauchst
  1. Trek 820 Tail Light Mounting Bracket Replacement, Tail Light Mounting Bracket: Schritt 1, Bild 1 von 1
    • Obtain one tail light mounting bracket and one screw as shown in the picture.
    • The screw should be removed from the mounting bracket.
  2. Trek 820 Tail Light Mounting Bracket Replacement: Schritt 2, Bild 1 von 1
    • Clean the bicycle seat post and mounting bracket.
    • Wrap the mounting bracket strap around the seat post.
    • Verify the larger piece rests towards the tail end aligned with the tires.
    • Verify the bracket's screw hole is on the right side of the bicycle.
  3. Trek 820 Tail Light Mounting Bracket Replacement: Schritt 3, Bild 1 von 2 Trek 820 Tail Light Mounting Bracket Replacement: Schritt 3, Bild 2 von 2
    • Locate the slot on the bracket where the strap will be inserted.
    • Insert the strap into the slot.
    • Tighten the strap just enough to keep the bracket in place.
  4. Trek 820 Tail Light Mounting Bracket Replacement: Schritt 4, Bild 1 von 2 Trek 820 Tail Light Mounting Bracket Replacement: Schritt 4, Bild 2 von 2
    • Insert the screw into the bracket screw hole.
    • Tighten the screw with fingers until the mounting bracket rests freely on seat post.
Abschluss
Cal Poly, Team 1-1, Propen Fall 2012 Mitglied von Cal Poly, Team 1-1, Propen Fall 2012
CPSU-PROPEN-F12S1G1
5 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 15
Insgesamt: 1,131
