Zum Hauptinhalt wechseln
Sony Vaio PCG-432L RAM Replacement
Was du brauchst
  1. Sony Vaio PCG-432L RAM Replacement, Opening up the Notebook: Schritt 1, Bild 1 von 2 Sony Vaio PCG-432L RAM Replacement, Opening up the Notebook: Schritt 1, Bild 2 von 2
    • Flip the computer over, and remove all screws circled in picture provided.
    • Set these screws aside for later in a place they will not be lost.
    • Flip the computer over and open the lid. Then take the trackpad/wrist-rest off the computer slightly but not too fast because there is a ribbon cable to disconnect. Once you have disconnected the ribbon cable set aside the assembly
    • Be careful! There is a delicate ribbon cable to detach before fully removing the assembly. Damaging/ripping this cable will render your trackpad useless.
    • Push the two white pieces holding the RAM aside and then push the RAM up.
    • Remove the RAM from the computer and set it aside.
    • Insert your replacement RAM into the slot, then push down gently until the plastic holders click and hold the RAM into place.
    • If the RAM does not go down fairly easily when you put it in, adjust it, don’t keep pushing because that’s an easy way to break your RAM.
    • Re-connect the ribbon cable from the trackpad/wrist-rest, then place the assembly down onto it’s mount and close the computer lid, and then flip it back over.
Abschluss
To reassemble your device, follow step 1 in reverse order.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
[deleted]
26.355 Reputation
21 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 236
