Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Humax IRHD 5000C zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Humax IRHD 5000C Teardown, open up case: Schritt 1, Bild 1 von 2 Humax IRHD 5000C Teardown, open up case: Schritt 1, Bild 2 von 2
    • Unscrew the screws on the outside.
    • Slide the top cover a bit to the back, and lift it from the enclosure.
  2. Humax IRHD 5000C Teardown, remove power supply: Schritt 2, Bild 1 von 2 Humax IRHD 5000C Teardown, remove power supply: Schritt 2, Bild 2 von 2
    • Remove the various pieces holding in the power supply.
    • Remove power cable (already cut of in the photo).
    • Unscrew screws.
    • Disconnect mainboard cables.
    • Remove the power supply from the enclosure.
  3. Humax IRHD 5000C Teardown, remove front: Schritt 3, Bild 1 von 2 Humax IRHD 5000C Teardown, remove front: Schritt 3, Bild 2 von 2
    • Disconnect the cables connecting the mainboard to the front panel.
    • With a flathead screwdriver, unclip the 2 topside clips, and 3 clips on the bottom of the enclosure, and the front will detach.
  4. Humax IRHD 5000C Teardown, disassemble front: Schritt 4, Bild 1 von 3 Humax IRHD 5000C Teardown, disassemble front: Schritt 4, Bild 2 von 3 Humax IRHD 5000C Teardown, disassemble front: Schritt 4, Bild 3 von 3
    • Unclip the 4 clips from left to right, and remove the panel.
    • With the pliers, clamp the white connector and push it through.
  5. Humax IRHD 5000C Teardown, remove mainboard: Schritt 5, Bild 1 von 2 Humax IRHD 5000C Teardown, remove mainboard: Schritt 5, Bild 2 von 2
    • Unscrew the screws and remove the mainboard from the case.
knipwim
8.527 Reputation
30 Anleitungen geschrieben
2 Kommentare
What are those unsoldered pad connectors for? A hard drive?
Jessica Parnelli Fawkes - Antwort
Don’t know, could be a SCSI drive, there are 68 pins. I included a detail picture in the last step.
knipwim -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 21
Insgesamt: 1,443
