Zum Hauptinhalt wechseln
How to Patch a Tear in Vinyl Furniture
Was du brauchst
  1. How to Patch a Tear in Vinyl Furniture, How to Patch a Tear in Vinyl Furniture: Schritt 1, Bild 1 von 1
    • Clean the damaged area with rubbing alcohol, using a rag, paper towel, or Q-tip.
  2. How to Patch a Tear in Vinyl Furniture: Schritt 2, Bild 1 von 1
    • Cut the backing fabric large enough to cover the tear, approximately half an inch larger around the tear.
  3. How to Patch a Tear in Vinyl Furniture: Schritt 3, Bild 1 von 2 How to Patch a Tear in Vinyl Furniture: Schritt 3, Bild 2 von 2
    • Use the spatula tool to insert the backing fabric underneath the tear.
  4. How to Patch a Tear in Vinyl Furniture: Schritt 4, Bild 1 von 2 How to Patch a Tear in Vinyl Furniture: Schritt 4, Bild 2 von 2
    • Use the spatula to apply the adhesive to the damaged area.
    • Choose a color that matches your furniture. You may need to mix colors to acheive the correct shade.
  5. How to Patch a Tear in Vinyl Furniture: Schritt 5, Bild 1 von 1
    • Let the adhesive dry for approximately four hours.
    • You may use a hair dryer to speed up the drying process.
  6. How to Patch a Tear in Vinyl Furniture: Schritt 6, Bild 1 von 2 How to Patch a Tear in Vinyl Furniture: Schritt 6, Bild 2 von 2
    • Use a Q-tip dipped in rubbing alcohol to buff and blend the area.
    • Apply light pressure to even out the edges.
Abschluss
Once the adhesive is dry, the furniture is ready for use!
4 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 14
Letzte 7 Tage: 72
Letzte 30 Tage: 315
Insgesamt: 24,526
