Zum Hauptinhalt wechseln
DigiTech RP70 Motherboard Replacement
Was du brauchst
  1. DigiTech RP70 Motherboard Replacement, Motherboard: Schritt 1, Bild 1 von 2 DigiTech RP70 Motherboard Replacement, Motherboard: Schritt 1, Bild 2 von 2
    • Unplug the device from its AC power adapter; unplug anything connected to the input/output jacks.
    • Remove the four 8mm Phillips #0 screws located on the back panel.
  2. DigiTech RP70 Motherboard Replacement: Schritt 2, Bild 1 von 2 DigiTech RP70 Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Remove the back panel to expose the motherboard.
  3. DigiTech RP70 Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Remove the two 11mm #0 Phillips screws located at the bottom of the motherboard.
  4. DigiTech RP70 Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Lift the indented end of the motherboard opposite the input/output jacks. Then, pull away from the input/output jacks to slide the motherboard out of the casing.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
3 Kommentare
My digitech rp 80 not work. How to get new motherboard
Thadevus - Antwort
My digitecj rp 80 not working. No display no sound how to get new motherboard
Thadevus - Antwort
Does anyone know where I can get the tone library push button/knob assy? Mine broke off.
Michael Adkins - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 4
Letzte 30 Tage: 10
Insgesamt: 885
