Zum Hauptinhalt wechseln
Removing the Back Panel of the Phone
Was du brauchst
  1. Removing the Back Panel of the Phone, Removing the Back Panel: Schritt 1, Bild 1 von 2 Removing the Back Panel of the Phone, Removing the Back Panel: Schritt 1, Bild 2 von 2
    • Orient the phone so that the phone model and other descriptive information is facing upward.
    • Locate the two silver screws near the hinge where the battery is housed.
    • Remove the silver screws using a Phillips head #2 screwdriver.
  2. Removing the Back Panel of the Phone: Schritt 2, Bild 1 von 3 Removing the Back Panel of the Phone: Schritt 2, Bild 2 von 3 Removing the Back Panel of the Phone: Schritt 2, Bild 3 von 3
    • Pull off the back panel of the phone.
    • Make sure you pull the cover off carefully in order to prevent damage to the back cover.
Abschluss
Clemson, Team 15-1, Benson Fall 2012 Mitglied von Clemson, Team 15-1, Benson Fall 2012
CLEM-BENSON-F12S15G1
4 Mitglieder
10 Anleitungen geschrieben
Ein Kommentar
Help I am still struggling to get the back cover off
caroline williams - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 12
Letzte 30 Tage: 67
Insgesamt: 4,495
