Zum Hauptinhalt wechseln
HP Pavilion 15-cc023cl Battery Replacement
Was du brauchst
  1. HP Pavilion 15-cc023cl Battery Replacement, Battery: Schritt 1, Bild 1 von 2 HP Pavilion 15-cc023cl Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Use a PH000 screwdriver to unscrew the eleven 4mm Phillip head screws located on the back panel.
  2. HP Pavilion 15-cc023cl Battery Replacement: Schritt 2, Bild 1 von 1
    • Using the iFixit opening tool, pry open and remove the back cover of the laptop.
    • Be gentle when applying force to the cover.
  3. HP Pavilion 15-cc023cl Battery Replacement: Schritt 3, Bild 1 von 2 HP Pavilion 15-cc023cl Battery Replacement: Schritt 3, Bild 2 von 2
    • Use a PH000 screwdriver to unscrew the four 3.5mm Philips head screws located on the battery.
  4. HP Pavilion 15-cc023cl Battery Replacement: Schritt 4, Bild 1 von 2 HP Pavilion 15-cc023cl Battery Replacement: Schritt 4, Bild 2 von 2
    • Disconnect the port connecting the battery and the motherboard and then remove.
Abschluss
7 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
We have a CD player on our laptop. Do we have to do something special with it?
ellenfk91 - Antwort
If you plan to replace it yeah, what do you even plan to replace? battery, no, harddrive, no, and im not sure about the other stuff.
Don't hurt the chickens -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 14
Letzte 30 Tage: 50
Insgesamt: 3,760
