Zum Hauptinhalt wechseln
Disassembling HP Mini 210 Back Case
Was du brauchst
  1. Disassembling HP Mini 210 Back Case, Battery: Schritt 1, Bild 1 von 2 Disassembling HP Mini 210 Back Case, Battery: Schritt 1, Bild 2 von 2
    • Turn off and unplug the netbook before replacing the battery.
    • Hold the netbook top-side down with the lid closed.
    • Slide the plastic battery release latches towards the lock symbols.
    • The left tab unlocks completely, but you will need to hold the right tab towards the lock symbol as you remove the battery.
  2. Disassembling HP Mini 210 Back Case: Schritt 2, Bild 1 von 1
    • Slide the battery out from the netbook.
  3. Disassembling HP Mini 210 Back Case, Disassembling HP Mini 210 Back Case: Schritt 3, Bild 1 von 1
    • Turn the netbook to view its edge.
    • Press both orange eject buttons simultaneously, and use a spudger to pry off the back case.
  4. Disassembling HP Mini 210 Back Case: Schritt 4, Bild 1 von 1
    • If the back case does not separate from the netbook easily, use the spudger to pry off the back case by the edge near the battery compartment, and work your way to the sides. The case will then pivot along the front edge.
  5. Disassembling HP Mini 210 Back Case: Schritt 5, Bild 1 von 1
    • Pull the back case off from the front edge.
Abschluss
12 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 9-17, Amido Fall 2012 Mitglied von Cal Poly, Team 9-17, Amido Fall 2012
CPSU-AMIDO-F12S9G17
3 Mitglieder
8 Anleitungen geschrieben
Ein Kommentar
Gracias!! esta guía fue muy util
Tony Ortega - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 9
Letzte 30 Tage: 41
Insgesamt: 20,902
