Zum Hauptinhalt wechseln
HP Mini 210 Hard Drive Replacement
Was du brauchst
  1. HP Mini 210 Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 2 HP Mini 210 Hard Drive Replacement, Battery: Schritt 1, Bild 2 von 2
    • Turn off and unplug the netbook before replacing the battery.
    • Hold the netbook top-side down with the lid closed.
    • Slide the plastic battery release latches towards the lock symbols.
    • The left tab unlocks completely, but you will need to hold the right tab towards the lock symbol as you remove the battery.
  2. HP Mini 210 Hard Drive Replacement: Schritt 2, Bild 1 von 1
    • Slide the battery out from the netbook.
  3. HP Mini 210 Hard Drive Replacement, Disassembling HP Mini 210 Back Case: Schritt 3, Bild 1 von 1
    • Turn the netbook to view its edge.
    • Press both orange eject buttons simultaneously, and use a spudger to pry off the back case.
  4. HP Mini 210 Hard Drive Replacement: Schritt 4, Bild 1 von 1
    • If the back case does not separate from the netbook easily, use the spudger to pry off the back case by the edge near the battery compartment, and work your way to the sides. The case will then pivot along the front edge.
  5. HP Mini 210 Hard Drive Replacement: Schritt 5, Bild 1 von 1
    • Pull the back case off from the front edge.
  6. HP Mini 210 Hard Drive Replacement, Hard Drive: Schritt 6, Bild 1 von 1
    • Peel back the black sticker covering the hard drive with tweezers or your fingers.
  7. HP Mini 210 Hard Drive Replacement: Schritt 7, Bild 1 von 1
    • Use a plastic opening tool to carefully disconnect the hard drive connector found above the RAM slot.
  8. HP Mini 210 Hard Drive Replacement: Schritt 8, Bild 1 von 2 HP Mini 210 Hard Drive Replacement: Schritt 8, Bild 2 von 2
    • Pull the silver plastic tab up and remove the hard drive. The tab may also be black.
    • Be aware of the 4 foam cushions on each corner of the hard drive as they may become loose during removal.
Abschluss
14 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 9-17, Amido Fall 2012 Mitglied von Cal Poly, Team 9-17, Amido Fall 2012
CPSU-AMIDO-F12S9G17
3 Mitglieder
8 Anleitungen geschrieben
Ein Kommentar
Be aware that some models don't have buttons but a orange switch that need some pressure to release the cover
Alejandro - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 11
Letzte 30 Tage: 35
Insgesamt: 18,150
