Einleitung
Is one side of your Hover-1 Horizon unresponsive? This is a guide to show you how to replace the left gyroscope board, the most likely culprit to your problem. This guide requires a Phillips #2 and a Phillips #1 screwdriver.
Was du brauchst
Remove the two connectors on either side of the board by lifting the tab and pulling out.
Remove the connector in the middle of the board by squeezing the tab and pulling up.
Remove the four 11mm Phillips #1 screws that attach the gyroscope board to the mount.
Lift the board to reveal the connections on the bottom.
Remove the four 12mm Phillips #2 screws that hold the motherboard to the base.
Pull the motherboard away from the gyroscope by grabbing it with two hands and pulling it to the right .
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
