Zum Hauptinhalt wechseln
Hover-1 Titan Battery Replacement
Was du brauchst
  1. Hover-1 Titan Battery Replacement, Bottom Right Panel: Schritt 1, Bild 1 von 2 Hover-1 Titan Battery Replacement, Bottom Right Panel: Schritt 1, Bild 2 von 2
    • Flip the hoverboard so the bottom is facing up.
    • The right side is the side that has the power button. There is also an "R" on the metal plate underneath the battery.
  2. Hover-1 Titan Battery Replacement: Schritt 2, Bild 1 von 2 Hover-1 Titan Battery Replacement: Schritt 2, Bild 2 von 2
    • Using a Phillips #1 screwdriver, remove the two 14 mm screws closest to the center of the hoverboard.
    • Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
    • Using a Phillips #1 screwdriver, remove the two 15 mm screws located closest to the wheel.
  3. Hover-1 Titan Battery Replacement: Schritt 3, Bild 1 von 3 Hover-1 Titan Battery Replacement: Schritt 3, Bild 2 von 3 Hover-1 Titan Battery Replacement: Schritt 3, Bild 3 von 3
    • Grip the bottom right panel and lift to remove it.
  4. Hover-1 Titan Battery Replacement, Battery: Schritt 4, Bild 1 von 2 Hover-1 Titan Battery Replacement, Battery: Schritt 4, Bild 2 von 2
    • Unplug the battery from the gyroscope/motherboard by holding the yellow connector and pulling apart.
  5. Hover-1 Titan Battery Replacement: Schritt 5, Bild 1 von 2 Hover-1 Titan Battery Replacement: Schritt 5, Bild 2 von 2
    • Remove the bundle of wires from the clip on the top of the battery.
  6. Hover-1 Titan Battery Replacement: Schritt 6, Bild 1 von 2 Hover-1 Titan Battery Replacement: Schritt 6, Bild 2 von 2
    • Using a Phillips #1 screwdriver, remove the four 14 mm screws that hold the battery on the device.
  7. Hover-1 Titan Battery Replacement: Schritt 7, Bild 1 von 3 Hover-1 Titan Battery Replacement: Schritt 7, Bild 2 von 3 Hover-1 Titan Battery Replacement: Schritt 7, Bild 3 von 3
    • Remove the battery out of the hoverboard by lifting the battery then sliding it out from under the wires.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Jessica Ouyang
619 Reputation
4 Anleitungen geschrieben
Cal Poly, Team S15-G4, White Fall 2018 Mitglied von Cal Poly, Team S15-G4, White Fall 2018
CPSU-WHITE-F18S15G4
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 39
Insgesamt: 1,951
