Zum Hauptinhalt wechseln
Hover-1 Titan Right Gyroscope Replacement
Was du brauchst
  1. Hover-1 Titan Right Gyroscope Replacement, Bottom Right Panel: Schritt 1, Bild 1 von 2 Hover-1 Titan Right Gyroscope Replacement, Bottom Right Panel: Schritt 1, Bild 2 von 2
    • Flip the hoverboard so the bottom is facing up.
    • The right side is the side that has the power button. There is also an "R" on the metal plate underneath the battery.
  2. Hover-1 Titan Right Gyroscope Replacement: Schritt 2, Bild 1 von 2 Hover-1 Titan Right Gyroscope Replacement: Schritt 2, Bild 2 von 2
    • Using a Phillips #1 screwdriver, remove the two 14 mm screws closest to the center of the hoverboard.
    • Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
    • Using a Phillips #1 screwdriver, remove the two 15 mm screws located closest to the wheel.
  3. Hover-1 Titan Right Gyroscope Replacement: Schritt 3, Bild 1 von 3 Hover-1 Titan Right Gyroscope Replacement: Schritt 3, Bild 2 von 3 Hover-1 Titan Right Gyroscope Replacement: Schritt 3, Bild 3 von 3
    • Grip the bottom right panel and lift to remove it.
  4. Hover-1 Titan Right Gyroscope Replacement, Right Gyroscope and Motherboard: Schritt 4, Bild 1 von 2 Hover-1 Titan Right Gyroscope Replacement, Right Gyroscope and Motherboard: Schritt 4, Bild 2 von 2
    • Unplug the battery from the gyroscope/motherboard by holding the yellow connector and pulling apart.
  5. Hover-1 Titan Right Gyroscope Replacement: Schritt 5, Bild 1 von 3 Hover-1 Titan Right Gyroscope Replacement: Schritt 5, Bild 2 von 3 Hover-1 Titan Right Gyroscope Replacement: Schritt 5, Bild 3 von 3
    • Remove four 12 mm Phillips #1 head screws from the corners of the green gyroscope/motherboard.
  6. Hover-1 Titan Right Gyroscope Replacement: Schritt 6, Bild 1 von 2 Hover-1 Titan Right Gyroscope Replacement: Schritt 6, Bild 2 von 2
    • Unplug the bottom left connector by squeezing it and pulling it away from the board.
  7. Hover-1 Titan Right Gyroscope Replacement: Schritt 7, Bild 1 von 2 Hover-1 Titan Right Gyroscope Replacement: Schritt 7, Bild 2 von 2
    • Unplug the white wires by squeezing the connector and pulling away from the board.
  8. Hover-1 Titan Right Gyroscope Replacement: Schritt 8, Bild 1 von 2 Hover-1 Titan Right Gyroscope Replacement: Schritt 8, Bild 2 von 2
    • Unplug one set of the red, white, purple, and black wires by squeezing the connector and pulling away from the board.
  9. Hover-1 Titan Right Gyroscope Replacement: Schritt 9, Bild 1 von 2 Hover-1 Titan Right Gyroscope Replacement: Schritt 9, Bild 2 von 2
    • Unplug the other set of the red, white, purple, and black wires by squeezing the connector and pulling away from the board.
  10. Hover-1 Titan Right Gyroscope Replacement: Schritt 10, Bild 1 von 1
    • Cut the cable tie and unplug the remaining wires.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Jessica Ouyang
619 Reputation
4 Anleitungen geschrieben
Cal Poly, Team S15-G4, White Fall 2018 Mitglied von Cal Poly, Team S15-G4, White Fall 2018
CPSU-WHITE-F18S15G4
4 Mitglieder
10 Anleitungen geschrieben
Ein Kommentar
Where can I get the circuit boards for the left and right ?
jfsucher - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 27
Insgesamt: 1,059
