Zum Hauptinhalt wechseln
2010-2017 Suzuki Swift Tail Light Bulb Replacement
Was du brauchst
  1. 2010-2017 Suzuki Swift Tail Light Bulb Replacement, loosen the tail light: Schritt 1, Bild 1 von 3 2010-2017 Suzuki Swift Tail Light Bulb Replacement, loosen the tail light: Schritt 1, Bild 2 von 3 2010-2017 Suzuki Swift Tail Light Bulb Replacement, loosen the tail light: Schritt 1, Bild 3 von 3
    • Unscrew the two visible bolts.
    • After unscrewing the bolts, the other side of the light is still fastened by two clickable plugs.
    • Using the panel removal tool, pry behind each corner and unclick each plug.
  2. 2010-2017 Suzuki Swift Tail Light Bulb Replacement, access backside of the light: Schritt 2, Bild 1 von 1
    • Remove the light from the frame and place it on the tailgate.
    • You might need to remove some of the cabling from cable guides.
    • You can also better see the plugs that held the light in place.
  3. 2010-2017 Suzuki Swift Tail Light Bulb Replacement, remove the fitting: Schritt 3, Bild 1 von 1
    • Unscrew the fitting about 45 degrees and lift it from the casing.
  4. 2010-2017 Suzuki Swift Tail Light Bulb Replacement, replace the bulb: Schritt 4, Bild 1 von 2 2010-2017 Suzuki Swift Tail Light Bulb Replacement, replace the bulb: Schritt 4, Bild 2 von 2
    • Remove the bulb by turning it about 45 degrees.
    • And do the reverse with the new bulb, push and turn.
    • The bulb has 2 guide pins assuring a correct install.
    • The fitting has 2 corresponding receivers.
  5. 2010-2017 Suzuki Swift Tail Light Bulb Replacement, insert fitting: Schritt 5, Bild 1 von 1
    • Insert the fitting by matching up the fitting guides with their openings on the casing and turn it 45 degrees clockwise.
  6. 2010-2017 Suzuki Swift Tail Light Bulb Replacement, put the light back: Schritt 6, Bild 1 von 1
    • Tuck back any cables you loosened, and place the light back on the car frame.
    • Make sure the replaced light actually works.
    • Push the light plugs back in.
    • Put the 2 screws back in.
    • You are done.
Ziellinie
5 weitere Nutzer:innen haben diese Anleitung absolviert.
knipwim
8.527 Reputation
30 Anleitungen geschrieben
Ein Kommentar
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 12
Letzte 7 Tage: 111
Letzte 30 Tage: 446
Insgesamt: 35,237
