Einleitung
This guide is created to replace a damaged or broken back wheel. Tools required are a Hex Bit 4.0 tool, a bit extender, and an allen key.
Was du brauchst
Remove either of the two 0.2 mm axle screws by using a hex bit 4.0 by turning clockwise.
Use a hex bit 4.0 to screw back in the 0.2 mm screw as tightly as possible by turning clockwise.
Flip over the scooter and use the hex bit 4.0 to remove the other 0.2 mm screw.
On the same side you removed the screw, use the bit extender to push down on the axle inside the wheel.
2 Kommentare
Where can you get replacement rubber for the front and rear wheels?
