Zum Hauptinhalt wechseln
Hover-1 Folding E-Scooter Rear Wheel Replacement
Was du brauchst
  1. Hover-1 Folding E-Scooter Rear Wheel Replacement, Rear Wheel: Schritt 1, Bild 1 von 2 Hover-1 Folding E-Scooter Rear Wheel Replacement, Rear Wheel: Schritt 1, Bild 2 von 2
    • Remove either of the two 0.2 mm axle screws by using a hex bit 4.0 by turning clockwise.
    • The two screws are the same thread so find the screw that has the least torque. Only that screw will be able to removed in this step.
    • Turn the hex bit 4.0 counterclockwise to reassemble the axle screws.
  2. Hover-1 Folding E-Scooter Rear Wheel Replacement: Schritt 2, Bild 1 von 3 Hover-1 Folding E-Scooter Rear Wheel Replacement: Schritt 2, Bild 2 von 3 Hover-1 Folding E-Scooter Rear Wheel Replacement: Schritt 2, Bild 3 von 3
    • Slide off the plastic side panel.
  3. Hover-1 Folding E-Scooter Rear Wheel Replacement: Schritt 3, Bild 1 von 1
    • Use a hex bit 4.0 to screw back in the 0.2 mm screw as tightly as possible by turning clockwise.
    • You will need to hold the other screw you are not replacing with an additional hex bit 4.0, so that the screws don't spin freely.
  4. Hover-1 Folding E-Scooter Rear Wheel Replacement: Schritt 4, Bild 1 von 1
    • Flip over the scooter and use the hex bit 4.0 to remove the other 0.2 mm screw.
  5. Hover-1 Folding E-Scooter Rear Wheel Replacement: Schritt 5, Bild 1 von 3 Hover-1 Folding E-Scooter Rear Wheel Replacement: Schritt 5, Bild 2 von 3 Hover-1 Folding E-Scooter Rear Wheel Replacement: Schritt 5, Bild 3 von 3
    • Slide off the other plastic side panel.
  6. Hover-1 Folding E-Scooter Rear Wheel Replacement: Schritt 6, Bild 1 von 1
    • On the same side you removed the screw, use the bit extender to push down on the axle inside the wheel.
    • The axle pops out and the wheel easily comes off.
    • Two washers will pop out with the axle.
Abschluss
Luke Imai
133 Reputation
1 Anleitung geschrieben
Cal Poly, Team S15-G5, White Fall 2018 Mitglied von Cal Poly, Team S15-G5, White Fall 2018
CPSU-WHITE-F18S15G5
4 Mitglieder
5 Anleitungen geschrieben
2 Kommentare
Where can you get replacement rubber for the front and rear wheels?
jackricotta - Antwort
How about adding a rear wheel removal article for the Hover-1 Alpha folding scooter?
sfaheysd - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 13
Letzte 30 Tage: 38
Insgesamt: 5,158
