Einleitung
Are you riding with risk because your brake no longer slows down your scooter? Learn how to replace your brake pad to make your scooter safe to ride again.
Was du brauchst
Remove either of the two 0.2 mm axle screws by using a hex bit 4.0 by turning clockwise.
Use a hex bit 4.0 to screw back in the 0.2 mm screw as tightly as possible by turning clockwise.
Flip over the scooter and use the hex bit 4.0 to remove the other 0.2 mm screw.
On the same side you removed the screw, use the bit extender to push down on the axle inside the wheel.
Remove the two 25mm screws by twisting a Phillips #2 screwdriver counterclockwise.
Remove the two 8 mm screws by twisting a Phillips #2 screwdriver counterclockwise.
Ein Kommentar
Hello, I have a hoverboard 1 scooter and I've charged it and it started going a couple days ago and then I came home and put it up and plugged it up for a couple hours and went to take off on it yesterday to go to a couple appointments and it would not go when I pushed off on it i only weight 128lbs so I know it's not my weight but how long do I normally charge it or should charge it without messing the battery pack up because I took it to a friend who is an electrician that I bought it from and he said he didn't know what could be wrong with it for me to call around to the scooter shops but no one has returned my calls and I need help with this matter asap if someone could please help me oh and also the scooter cuts on and shows 13 on the screen and as I push it it'll change to 94 like how am I walking 94mph I don't get it but the headlight works cause when I cut it on its bright and it cuts off when I hold the button but I also wanted to know if there was a reset button on this hoverboard 1 scooter
