Zum Hauptinhalt wechseln
Hover-1 Titan Wheel and Motor Replacement
Was du brauchst
  1. Hover-1 Titan Wheel and Motor Replacement, Bottom Left Panel: Schritt 1, Bild 1 von 2 Hover-1 Titan Wheel and Motor Replacement, Bottom Left Panel: Schritt 1, Bild 2 von 2
    • Flip the hoverboard so the bottom is facing up.
    • The left side is the side that has the charge port. There is also an "L" on the metal plate underneath the wires.
  2. Hover-1 Titan Wheel and Motor Replacement: Schritt 2, Bild 1 von 2 Hover-1 Titan Wheel and Motor Replacement: Schritt 2, Bild 2 von 2
    • Using a Phillips #1 screwdriver, remove the two 14 mm screws located closest to the center of the hoverboard.
    • Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
    • Using a Phillips #1 screwdriver, remove two 15 mm screws located closest to the wheel.
  3. Hover-1 Titan Wheel and Motor Replacement: Schritt 3, Bild 1 von 3 Hover-1 Titan Wheel and Motor Replacement: Schritt 3, Bild 2 von 3 Hover-1 Titan Wheel and Motor Replacement: Schritt 3, Bild 3 von 3
    • Grip the bottom left panel and lift up to remove.
  4. Hover-1 Titan Wheel and Motor Replacement, Wheel and Motor: Schritt 4, Bild 1 von 2 Hover-1 Titan Wheel and Motor Replacement, Wheel and Motor: Schritt 4, Bild 2 von 2
    • Unplug the battery by pulling apart the yellow connectors.
  5. Hover-1 Titan Wheel and Motor Replacement: Schritt 5, Bild 1 von 2 Hover-1 Titan Wheel and Motor Replacement: Schritt 5, Bild 2 von 2
    • Use the Phillips #1 screwdriver to remove the four 12mm screws that attach the gyroscope/motherboard to the hoverboard.
  6. Hover-1 Titan Wheel and Motor Replacement: Schritt 6, Bild 1 von 3 Hover-1 Titan Wheel and Motor Replacement: Schritt 6, Bild 2 von 3 Hover-1 Titan Wheel and Motor Replacement: Schritt 6, Bild 3 von 3
    • Cut the rubber surrounding the yellow wire and pull the rubber apart, exposing the connectors.
  7. Hover-1 Titan Wheel and Motor Replacement: Schritt 7, Bild 1 von 2 Hover-1 Titan Wheel and Motor Replacement: Schritt 7, Bild 2 von 2
    • Unplug the yellow wires by gripping the wire close to the connectors and pulling apart.
  8. Hover-1 Titan Wheel and Motor Replacement: Schritt 8, Bild 1 von 3 Hover-1 Titan Wheel and Motor Replacement: Schritt 8, Bild 2 von 3 Hover-1 Titan Wheel and Motor Replacement: Schritt 8, Bild 3 von 3
    • Cut the rubber surrounding the green wire and pull the rubber apart, exposing the connectors.
  9. Hover-1 Titan Wheel and Motor Replacement: Schritt 9, Bild 1 von 2 Hover-1 Titan Wheel and Motor Replacement: Schritt 9, Bild 2 von 2
    • Unplug the green wires by gripping the wire close to the connectors and pulling apart.
  10. Hover-1 Titan Wheel and Motor Replacement: Schritt 10, Bild 1 von 3 Hover-1 Titan Wheel and Motor Replacement: Schritt 10, Bild 2 von 3 Hover-1 Titan Wheel and Motor Replacement: Schritt 10, Bild 3 von 3
    • Cut the rubber surrounding the blue wire and pull the rubber apart, exposing the connectors.
  11. Hover-1 Titan Wheel and Motor Replacement: Schritt 11, Bild 1 von 2 Hover-1 Titan Wheel and Motor Replacement: Schritt 11, Bild 2 von 2
    • Unplug the blue wires by gripping the wire close to the connectors and pulling apart.
  12. Hover-1 Titan Wheel and Motor Replacement: Schritt 12, Bild 1 von 3 Hover-1 Titan Wheel and Motor Replacement: Schritt 12, Bild 2 von 3 Hover-1 Titan Wheel and Motor Replacement: Schritt 12, Bild 3 von 3
    • Unplug the rainbow connector by squeezing the clips and pulling apart.
  13. Hover-1 Titan Wheel and Motor Replacement: Schritt 13, Bild 1 von 2 Hover-1 Titan Wheel and Motor Replacement: Schritt 13, Bild 2 von 2
    • Use scissors to cut the zip tie around the group of wires.
  14. Hover-1 Titan Wheel and Motor Replacement: Schritt 14, Bild 1 von 3 Hover-1 Titan Wheel and Motor Replacement: Schritt 14, Bild 2 von 3 Hover-1 Titan Wheel and Motor Replacement: Schritt 14, Bild 3 von 3
    • Unplug the white wire connector by squeezing the clips and pulling apart.
  15. Hover-1 Titan Wheel and Motor Replacement: Schritt 15, Bild 1 von 2 Hover-1 Titan Wheel and Motor Replacement: Schritt 15, Bild 2 von 2
    • Use an impact driver with a hex 6 bit to loosen the four 20 mm hex 6 bolts.
    • Wear safety glasses while using the impact driver.
  16. Hover-1 Titan Wheel and Motor Replacement: Schritt 16, Bild 1 von 3 Hover-1 Titan Wheel and Motor Replacement: Schritt 16, Bild 2 von 3 Hover-1 Titan Wheel and Motor Replacement: Schritt 16, Bild 3 von 3
    • Pull out the loosened screws with your hands and remove the metal plate.
  17. Hover-1 Titan Wheel and Motor Replacement: Schritt 17, Bild 1 von 2 Hover-1 Titan Wheel and Motor Replacement: Schritt 17, Bild 2 von 2
    • Lift the wheel and motor shaft up and out of the board.
    • The motor shaft is located within the wheel.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Emma Huun
312 Reputation
1 Anleitung geschrieben
Cal Poly, Team S15-G4, White Fall 2018 Mitglied von Cal Poly, Team S15-G4, White Fall 2018
CPSU-WHITE-F18S15G4
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 14
Letzte 30 Tage: 43
Insgesamt: 1,668
