Zum Hauptinhalt wechseln
How to remove and clean the Dyson DC14 filter
Was du brauchst
  1. How to remove and clean the Dyson DC14 filter, How to remove and clean the Dyson DC14 filter: Schritt 1, Bild 1 von 1
    • The filter is located in the canister of your vacuum.
  2. How to remove and clean the Dyson DC14 filter: Schritt 2, Bild 1 von 3 How to remove and clean the Dyson DC14 filter: Schritt 2, Bild 2 von 3 How to remove and clean the Dyson DC14 filter: Schritt 2, Bild 3 von 3
    • Open the canister filter compartment. Push the clip upwards, and open the canister top away from you.
    • Remove the yellow filter housing.
  3. How to remove and clean the Dyson DC14 filter: Schritt 3, Bild 1 von 1
    • Remove the blue sponge-filter from the yellow filter housing.
    • The filter and housing must both be completely dry before reinstalling. Do not use your vacuum without filters installed.
    • Clean the blue sponge-filter in cold water until the water runs clear.
Abschluss
Once the filter is cleaned, set the blue filter sponge and the yellow filter housing aside for at least 24 hours to dry. Do not use your vacuum without a filter, or when the filter is still wet. To reassemble, follow the steps in reverse order.
17 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 3-22, Amido Fall 2012 Mitglied von Cal Poly, Team 3-22, Amido Fall 2012
CPSU-AMIDO-F12S3G22
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 21
Letzte 30 Tage: 111
Insgesamt: 39,807
