Was du brauchst
Remove Battery and Strap from unit.
Remove the 3 screws from the bottom
Remove screws from both sides of unit (4 screws total)
Remove both side panels from unit. You can pry them off with your finger nail or a spudger
Release the Ziff clamp holding the LCD cable. 1st photo shows clamp in closed position.
You can use a spudger to release the clamp. You can also use your finger nail, but be careful it is very fragile.
Remove the LCD Flex from the clamp
You may need to pry off the window plate of your old screen if the new screen doesn't have one.
If required: Remove the window plate from your old screen if your new LCD doesn't have one. Save this part for re-install.
In diesem Schritt verwendetes Werkzeug:Microfiber Cleaning Cloths$3.99
If your new LCD does not come with a window plate: Tape your old window plate in place as shown in the photo. Make sure it lines up properly and fits into the grooves. This makes re-assembly much easier.
If necessary clean the window plate and LCD with a micro fiber dry cloth. Make sure there is no debris or dust before you re-install. DO NOT use any liquids.
Now just reverse the steps to re-assemble your camera with the new screen.
