Zum Hauptinhalt wechseln
Casio CTK-501 Speaker Replacement
Was du brauchst
  1. Casio CTK-501 Speaker Replacement, Bottom Panel: Schritt 1, Bild 1 von 2 Casio CTK-501 Speaker Replacement, Bottom Panel: Schritt 1, Bild 2 von 2
    • Flip the keyboard over so that the bottom is facing up.
    • Remove the twenty-seven 12 mm screws from the dark-grey panel using a Phillips #2 screwdriver.
  2. Casio CTK-501 Speaker Replacement: Schritt 2, Bild 1 von 1
    • Remove the bottom panel by lifting and pulling it towards yourself.
  3. Casio CTK-501 Speaker Replacement: Schritt 3, Bild 1 von 2 Casio CTK-501 Speaker Replacement: Schritt 3, Bild 2 von 2
    • Flip open the top half of the keyboard.
    • Set the keyboard onto the bottom half with the internal parts facing up.
    • Be careful not to let the bottom drop.
  4. Casio CTK-501 Speaker Replacement, Speaker: Schritt 4, Bild 1 von 1
    • Plug in the soldering iron and place somewhere safe to avoid burning yourself or causing a fire.
    • Completely unscrew and remove all four screws in the corners of the speaker.
  5. Casio CTK-501 Speaker Replacement: Schritt 5, Bild 1 von 1
    • Pull the speaker out of the keyboard and set on a flat surface to solder safely.
  6. Casio CTK-501 Speaker Replacement: Schritt 6, Bild 1 von 1
    • Be careful when removing the wires and avoid dripping solder on yourself or the keyboard.
    • Touch soldering iron to solder over the end of the wires, and when the solder melts, pull the wires away from the speaker.
    • Remove the speaker and replace with a new one.
  7. Casio CTK-501 Speaker Replacement: Schritt 7, Bild 1 von 1
    • Strip the wires if you need more clean metal to solder to the speaker.
    • Use the soldering iron to melt the solder over the wire to connect them to the speaker.
  8. Casio CTK-501 Speaker Replacement: Schritt 8, Bild 1 von 1
    • Completely screw in the screws back into the original positions on the corner of the speaker.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Jimmy Winne
578 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 9-16, Amido Fall 2012 Mitglied von Cal Poly, Team 9-16, Amido Fall 2012
CPSU-AMIDO-F12S9G16
4 Mitglieder
Ein Kommentar
I have a Casio ctk 691 Keyboard and it’s not Turning up is working is coming on but my volume slider is not working
Jacameron Bussey - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 25
Insgesamt: 6,452
