Einleitung
Installing a tube.
Was du brauchst
Using the 4mm Allen wrench, partially unscrew the 4 (22mm) hex screws on the front of the axle casing to allow the axle to slide freely.
Using the 8mm Allen wrench, loosen the axle screw until 1/2 of the axle screw is visible.
Push the axle screw to reveal the axle rod on the other side.
Look at your tire and determine the correct tube size by locating the number (formated ## x #.##) on the wall of the tire.
Unscrew the cap covering the valve.
Remove the spacer that holds the valve in place against the rim of the wheel.
Open the valve by turning the nut and pressing the valve in to release air pressure from the tube.
Slide the tire lever between the tire and the rim.
Push down on the tire lever until the edge of the tire is higher than the edge of the rim.
Insert a second tire lever adjacent to the first.
Slowly work one tire lever around the rim until the whole tire is loose.
Push the valve through the rim.
Push the tube into the tire all the way around the rim of the wheel.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
