Zum Hauptinhalt wechseln
HP Mini 210-2070NR Battery and Service Access Cover Replacement
  1. HP Mini 210-2070NR Battery and Service Access Cover Replacement, Battery and Service Access Cover: Schritt 1, Bild 1 von 1
    • Before beginning, make sure that your computer is turned off and all external power cords are disconnected.
    • Close the laptop and turn it over so that the underside is up and the silver battery bay is facing towards you.
  2. HP Mini 210-2070NR Battery and Service Access Cover Replacement: Schritt 2, Bild 1 von 3 HP Mini 210-2070NR Battery and Service Access Cover Replacement: Schritt 2, Bild 2 von 3 HP Mini 210-2070NR Battery and Service Access Cover Replacement: Schritt 2, Bild 3 von 3
    • The battery locking latch is on the bottom right corner; slide it inward to unlock the battery.
    • Slide the battery release latch inwards.
    • Pull the battery towards you to remove it.
  3. HP Mini 210-2070NR Battery and Service Access Cover Replacement: Schritt 3, Bild 1 von 3 HP Mini 210-2070NR Battery and Service Access Cover Replacement: Schritt 3, Bild 2 von 3 HP Mini 210-2070NR Battery and Service Access Cover Replacement: Schritt 3, Bild 3 von 3
    • Slide the service access cover release lever to the right.
    • While holding the lever to the right, lift up the laptop's bottom cover gently and remove the cover.
  4. HP Mini 210-2070NR Battery and Service Access Cover Replacement: Schritt 4, Bild 1 von 1
    • Orient the computer as shown in the picture.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Sean Kuster
91 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 3-23, Amido Fall 2012 Mitglied von Cal Poly, Team 3-23, Amido Fall 2012
CPSU-AMIDO-F12S3G23
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 13
Insgesamt: 1,457
