Zum Hauptinhalt wechseln
How to Enable the Charging Chime on a Mac Laptop with a MagSafe Charger
  1. How to Enable the Charging Chime on a Mac Laptop with a MagSafe Charger, How to Enable the Charging Chime on a Mac Laptop with a MagSafe Charger: Schritt 1, Bild 1 von 1
    • Disconnect your MagSafe/MagSafe 2 power adapter.
    • Go to the spotlight search and search for Terminal. Open Terminal by double clicking it in the results area.
    • Paste the following command into the Terminal window and press enter
    • defaults write com.apple.PowerChime ChimeOnAllHardware -bool true; open /System/Library/CoreServices/PowerChime.app &
    • Terminal may automatically press enter for you. This may vary depending upon circumstances.
    • Done! Reconnect your MagSafe/MagSafe 2 power adapter and you should hear the charging chime
    • Your volume must be raised in order to hear the chime.
Abschluss
To disable the charging chime, simply change -bool true; in the command above to -bool false;
17 weitere Nutzer:innen haben diese Anleitung absolviert.
[deleted]
26.409 Reputation
21 Anleitungen geschrieben
3 Kommentare
This is cool, thank you!
Ryan Koenigsman - Antwort
how to DISABLE THIS SOUND ? :)
Mars is flat too... - Antwort
Hey there! You are able to turn off the chime by simply changing the command:
Turn on:
Turn off:
defaults write com.apple.PowerChime ChimeOnAllHardware -bool false; open /System/Library/CoreServices/PowerChime.app &
Difference is that the ‘on’ command states true and the off command states ‘false’
Try to attempt this, it may not work depending on your mac
EB R -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 10
Letzte 7 Tage: 60
Letzte 30 Tage: 232
Insgesamt: 9,109
