Einleitung
Many small tires use inner tubes which are tubes that hold the air pressure for the tire. It is common for inner tubes to leak air pressure or get punctured. Replacing the inner tube is easy. The process requires you to remove the tire from the rim, swap the old inner tube with a new inner tube, and then reassemble the tire to inflate it.
Was du brauchst
Press the valve all the way down with a screwdriver to release the air pressure.
Use a 5/32 inch hex key to unscrew the 5/32 hex-head bolts that hold the rim halves together.
Flip the tire so that the bottom side is on the top now.
Pull out the bottom rim half that contains the nuts for the bolts.
Don't forget to visually inspect outside of tire for foreign objects that may have punctured your original tube. Also feel around inside of tire carefully for such objects (nails, screws, wire, thorns, etc).
Use two fingers to uniformly push the replacement inner tube into the inside of the tire.
Gently pull out the valve stem so that it faces you. You may have to flip the tire to make it face you.
Take the bottom rim half and partially push it into the bottom of the tire. The bottom rim half contains the nuts for the bolts.
Align the valve stem cutout in the bottom rim half with the valve stem.
Push the bottom rim half into the tire until the valve stem and rim touch.
Locate the valve stem cutout on the top rim half.
Align the valve stem cutout on the top rim half with the valve stem.
Push the top rim half into the tire until the two rim halves touch.
Insert all the bolts into the top rim half.
Use a 5/32 inch hex key to screw the bolts in.
Use an air compressor with a tire inflator attachment (or any car tire inflator) to inflate the tire.
The tire is now ready to be attached to its axle.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
