Zum Hauptinhalt wechseln
WDT P605-02 4.10-5 B-PR Tire Inner Tube Replacement
Was du brauchst
  1. WDT P605-02 4.10-5 B-PR Tire Inner Tube Replacement, Inner Tube: Schritt 1, Bild 1 von 1
    • Unscrew the valve cap from the valve stem.
  2. WDT P605-02 4.10-5 B-PR Tire Inner Tube Replacement: Schritt 2, Bild 1 von 1
    • Press the valve all the way down with a screwdriver to release the air pressure.
  3. WDT P605-02 4.10-5 B-PR Tire Inner Tube Replacement: Schritt 3, Bild 1 von 1
    • Use a 5/32 inch hex key to unscrew the 5/32 hex-head bolts that hold the rim halves together.
    • This step may differ depending on the type of rim. Some rims may require you to pry the rim out of the tire.
  4. WDT P605-02 4.10-5 B-PR Tire Inner Tube Replacement: Schritt 4, Bild 1 von 3 WDT P605-02 4.10-5 B-PR Tire Inner Tube Replacement: Schritt 4, Bild 2 von 3 WDT P605-02 4.10-5 B-PR Tire Inner Tube Replacement: Schritt 4, Bild 3 von 3
    • Pull out the rim half that contained the heads of the bolts.
  5. WDT P605-02 4.10-5 B-PR Tire Inner Tube Replacement: Schritt 5, Bild 1 von 3 WDT P605-02 4.10-5 B-PR Tire Inner Tube Replacement: Schritt 5, Bild 2 von 3 WDT P605-02 4.10-5 B-PR Tire Inner Tube Replacement: Schritt 5, Bild 3 von 3
    • Flip the tire so that the bottom side is on the top now.
    • Pull out the bottom rim half that contains the nuts for the bolts.
  6. WDT P605-02 4.10-5 B-PR Tire Inner Tube Replacement: Schritt 6, Bild 1 von 3 WDT P605-02 4.10-5 B-PR Tire Inner Tube Replacement: Schritt 6, Bild 2 von 3 WDT P605-02 4.10-5 B-PR Tire Inner Tube Replacement: Schritt 6, Bild 3 von 3
    • Pinch the deflated inner tube and pull out the inner tube completely.
    • Don't forget to visually inspect outside of tire for foreign objects that may have punctured your original tube. Also feel around inside of tire carefully for such objects (nails, screws, wire, thorns, etc).
  7. WDT P605-02 4.10-5 B-PR Tire Inner Tube Replacement: Schritt 8, Bild 1 von 2 WDT P605-02 4.10-5 B-PR Tire Inner Tube Replacement: Schritt 8, Bild 2 von 2
    • Take the replacement inner tube and spread it out with your hands.
  8. WDT P605-02 4.10-5 B-PR Tire Inner Tube Replacement: Schritt 9, Bild 1 von 3 WDT P605-02 4.10-5 B-PR Tire Inner Tube Replacement: Schritt 9, Bild 2 von 3 WDT P605-02 4.10-5 B-PR Tire Inner Tube Replacement: Schritt 9, Bild 3 von 3
    • Use two fingers to uniformly push the replacement inner tube into the inside of the tire.
  9. WDT P605-02 4.10-5 B-PR Tire Inner Tube Replacement: Schritt 10, Bild 1 von 1
    • Spread the replacement inner tube evenly against the walls of the tire.
    • The inner tube must not be folded in half or crammed into only a portion of the tire.
  10. WDT P605-02 4.10-5 B-PR Tire Inner Tube Replacement: Schritt 11, Bild 1 von 3 WDT P605-02 4.10-5 B-PR Tire Inner Tube Replacement: Schritt 11, Bild 2 von 3 WDT P605-02 4.10-5 B-PR Tire Inner Tube Replacement: Schritt 11, Bild 3 von 3
    • Gently pull out the valve stem so that it faces you. You may have to flip the tire to make it face you.
    • Take the bottom rim half and partially push it into the bottom of the tire. The bottom rim half contains the nuts for the bolts.
    • Align the valve stem cutout in the bottom rim half with the valve stem.
    • Push the bottom rim half into the tire until the valve stem and rim touch.
  11. WDT P605-02 4.10-5 B-PR Tire Inner Tube Replacement: Schritt 12, Bild 1 von 3 WDT P605-02 4.10-5 B-PR Tire Inner Tube Replacement: Schritt 12, Bild 2 von 3 WDT P605-02 4.10-5 B-PR Tire Inner Tube Replacement: Schritt 12, Bild 3 von 3
    • Locate the valve stem cutout on the top rim half.
    • Align the valve stem cutout on the top rim half with the valve stem.
    • Push the top rim half into the tire until the two rim halves touch.
  12. WDT P605-02 4.10-5 B-PR Tire Inner Tube Replacement: Schritt 13, Bild 1 von 1
    • Insert all the bolts into the top rim half.
    • Use a 5/32 inch hex key to screw the bolts in.
  13. WDT P605-02 4.10-5 B-PR Tire Inner Tube Replacement: Schritt 14, Bild 1 von 2 WDT P605-02 4.10-5 B-PR Tire Inner Tube Replacement: Schritt 14, Bild 2 von 2
    • Use an air compressor with a tire inflator attachment (or any car tire inflator) to inflate the tire.
    • The pressure of the tire must not exceed 22PSI.
  14. WDT P605-02 4.10-5 B-PR Tire Inner Tube Replacement: Schritt 15, Bild 1 von 1
    • Screw the valve cap onto the valve stem.
Abschluss
The tire is now ready to be attached to its axle.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 19
Insgesamt: 660
