Zum Hauptinhalt wechseln
Dyson DC14 Motor Replacement
Was du brauchst
  1. Dyson DC14 Motor Replacement, Brush Bar: Schritt 1, Bild 1 von 1
    • Turn off the vacuum and unplug it from the outlet.
    • Lay the vacuum on its top so that the brush bar faces you.
  2. Dyson DC14 Motor Replacement: Schritt 2, Bild 1 von 3 Dyson DC14 Motor Replacement: Schritt 2, Bild 2 von 3 Dyson DC14 Motor Replacement: Schritt 2, Bild 3 von 3
    • Using a quarter, turn the three soleplate fasteners 90 degrees to the left.
    • Holding the soleplate on both sides, tilt it down and away from the vacuum.
    • Remove the soleplate from the vacuum.
  3. Dyson DC14 Motor Replacement: Schritt 3, Bild 1 von 2 Dyson DC14 Motor Replacement: Schritt 3, Bild 2 von 2
    • Turn down the squared tabs on the brushbar so that they face outward.
    • Use a screwdriver to pry the belt up from the brushbar.
    • Be careful not to cut the belt with the screwdriver.
    • While holding the belt, pull the brushbar to the left and remove it from the vacuum.
    • You can let go of the belt when it's free from the brushbar. The belt will not retract into the vacuum.
    • During reassembly, insert the brushbar with the tabs facing outward, then rotate the tabs up to lock the brushbar in place.
  4. Dyson DC14 Motor Replacement, Motor: Schritt 4, Bild 1 von 2 Dyson DC14 Motor Replacement, Motor: Schritt 4, Bild 2 von 2
    • Place vacuum upright, with the canister facing you.
    • Remove the canister, setting the canister aside.
  5. Dyson DC14 Motor Replacement: Schritt 5, Bild 1 von 3 Dyson DC14 Motor Replacement: Schritt 5, Bild 2 von 3 Dyson DC14 Motor Replacement: Schritt 5, Bild 3 von 3
    • Insert flathead screwdriver under each latch and pry up gently.
    • Do not try to lift the latches up very far, they could snap off!
    • Open the cover, remove the exhaust filter, and set the filter to the side
  6. Dyson DC14 Motor Replacement: Schritt 6, Bild 1 von 2 Dyson DC14 Motor Replacement: Schritt 6, Bild 2 von 2
    • Place vacuum face down.
    • Remove the u-bend pipe that connects the canister to the telescopic wand.
  7. Dyson DC14 Motor Replacement: Schritt 7, Bild 1 von 2 Dyson DC14 Motor Replacement: Schritt 7, Bild 2 von 2
    • Pull the clear hose out of the gasket on the right side of the vacuum under the axle.
    • Pull the hose straight back towards you.
  8. Dyson DC14 Motor Replacement: Schritt 8, Bild 1 von 2 Dyson DC14 Motor Replacement: Schritt 8, Bild 2 von 2
    • Remove brush-bar housing by prying the housing out of the clips that hold it.
    • Pull brush-bar housing toward you while keeping vacuum stationary.
  9. Dyson DC14 Motor Replacement: Schritt 9, Bild 1 von 1
    • Remove the three T15 torx screws that secure the cover to the brush clutch belt.
  10. Dyson DC14 Motor Replacement: Schritt 10, Bild 1 von 2 Dyson DC14 Motor Replacement: Schritt 10, Bild 2 von 2
    • Pull the cover of the brush clutch belt out towards you.
    • Pull belt to the right to remove the belt from the brush clutch axle.
    • To reassemble your vacuum, pull the belt with your finger towards the axle. (Using a screwdriver, or a similar device, will delay access to the axle.)
  11. Dyson DC14 Motor Replacement: Schritt 11, Bild 1 von 2 Dyson DC14 Motor Replacement: Schritt 11, Bild 2 von 2
    • Insert a flat-head screwdriver into the two locking rings to remove the rings, which are located above the wheels on both sides.
    • These rings secure the bottom assembly of the vacuum to the rest of the unit.
  12. Dyson DC14 Motor Replacement: Schritt 12, Bild 1 von 2 Dyson DC14 Motor Replacement: Schritt 12, Bild 2 von 2
    • Remove the four T15 torx screws that secure the motor housing to the vacuum.
    • Remove the elbow-bend pipe on the right-side of the vacuum.
    • Press the two release latches on either side of the elbow-bend pipe. Pull it out and away from the vacuum.
  13. Dyson DC14 Motor Replacement: Schritt 13, Bild 1 von 1
    • Place the vacuum right-side up and leave it standing up.
    • Remove the right side cover by pushing the release latch down while lifting the cover towards you.
  14. Dyson DC14 Motor Replacement: Schritt 14, Bild 1 von 2 Dyson DC14 Motor Replacement: Schritt 14, Bild 2 von 2
    • Set vacuum the on its back.
    • Pull away the plastic cover of the motor housing.
    • A bit of force may be needed.
  15. Dyson DC14 Motor Replacement: Schritt 15, Bild 1 von 1
    • Insert flat head screwdriver between gray motor housing and black motor.
    • Pry motor cover housing away.
  16. Dyson DC14 Motor Replacement: Schritt 16, Bild 1 von 2 Dyson DC14 Motor Replacement: Schritt 16, Bild 2 von 2
    • Release the motor assembly from its housing by strongly hitting the brush clutch axle with a hammer.
    • The rubber grommets covering the motor may be greasy.
  17. Dyson DC14 Motor Replacement: Schritt 17, Bild 1 von 1
    • Remove motor from housing slowly.
    • Do not pull the motor completely out of the housing. The motor is connected to the vacuum by two wires.
  18. Dyson DC14 Motor Replacement: Schritt 18, Bild 1 von 2 Dyson DC14 Motor Replacement: Schritt 18, Bild 2 von 2
    • Remove the power terminals from both sides of the motor.
    • Do not pull by the wires when removing terminal. This can result in damage to your vacuum.
    • These terminals will only fit one way (i.e. only one end is long enough to reach to the far side of the motor).
    • Remove the motor from the housing completely.
  19. Dyson DC14 Motor Replacement: Schritt 19, Bild 1 von 1
    • Remove the two rubber grommets from your old motor, then transfer them to your new motor.
Abschluss
22 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 3-22, Amido Fall 2012 Mitglied von Cal Poly, Team 3-22, Amido Fall 2012
CPSU-AMIDO-F12S3G22
4 Mitglieder
8 Anleitungen geschrieben
12 Kommentare
Rather than use a screwdriver for belt removal & risk injury or machine damage, why not use the proper belt tool ?. It saves time & possible injury and is available for not much more than the cost of a decent quality flat head screwdriver.
Andy - Antwort
Motor works beater bar does not turn
carlalewis -
What if its not the motor
carlalewis - Antwort
Great guide! A useful tip for getting the motor (or specifically the rubber cover) into the motor case: smear some washing up liquid or liquid soap around the inside of the motor case, and the rubber will slip in a lot easier. Keep an eye nf the rotational position of the motor (so that it fits the hole at the axle end correctly), and make sure you don't trap the 2 power wires.
Paul Blitz - Antwort
Great tutorial, replacement motor cost £12, Dyson now back up and working. Only issue I had was that when replacing the motor housing in the Hoover, make sure it fits into the bottom groove or else the screw hole on the brush clutch cover won't line up. You'll know it's not in the groove if you're having trouble with the screw. Just go back and under the four screws, lift out the motor housing and seat it in again, that'll sort it out.
Blue - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 24
Letzte 30 Tage: 67
Insgesamt: 53,698
