Zum Hauptinhalt wechseln
Repairing Bose On-Ear headphones Shorted Right earphone
Was du brauchst
  1. Repairing Bose On-Ear headphones Shorted Right earphone, Repairing Bose On-Ear headphones Shorted Right earphone: Schritt 1, Bild 1 von 2 Repairing Bose On-Ear headphones Shorted Right earphone, Repairing Bose On-Ear headphones Shorted Right earphone: Schritt 1, Bild 2 von 2
    • To repair a short in the wires, the head band has two screws, just above the headphones cups.
  2. Repairing Bose On-Ear headphones Shorted Right earphone: Schritt 2, Bild 1 von 2 Repairing Bose On-Ear headphones Shorted Right earphone: Schritt 2, Bild 2 von 2
    • After removing the two small screws, try closing the headband to it's shortest position. The outer panel will pop out toward the bottom edge.
    • You can then slide the panel out from under the collar. The collar may slide out of place while working, but can easily be slid back during re-assembly.
  3. Repairing Bose On-Ear headphones Shorted Right earphone: Schritt 3, Bild 1 von 2 Repairing Bose On-Ear headphones Shorted Right earphone: Schritt 3, Bild 2 von 2
    • After inspecting the wire inside, you may notice cracks in the corners were the wires bend when the headphones are folded. I cut a thin strip of electrical tape to use as reinforcement.
    • After sliding the collar up, you can extend the wire, giving you better access for wrapping or replacing.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Designer Dan
274 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 17
Letzte 30 Tage: 33
Insgesamt: 5,141
