Zum Hauptinhalt wechseln
Sanyo Katana Eclipse X Battery Replacement
Was du brauchst
  1. Sanyo Katana Eclipse X Battery Replacement, Back Panel: Schritt 1, Bild 1 von 2 Sanyo Katana Eclipse X Battery Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Press the battery release button located on the back of the phone.
    • With the button depressed, pull down on the battery protector to remove it from the phone.
    • The phone's battery will now be exposed.
  2. Sanyo Katana Eclipse X Battery Replacement: Schritt 2, Bild 1 von 1
    • Slide a thin object under the white tab located on the bottom of the battery and carefully lift away from the phone.
    • A small, flat-tip screwdriver or credit card may be helpful for this step.
    • The battery should now be free of the phone.
  3. Sanyo Katana Eclipse X Battery Replacement, Battery: Schritt 3, Bild 1 von 1
    • Align the copper receptors on the back of your battery so the phone's copper receptors are touching the battery terminals.
    • Refer to photo illustrations.
    • Using your thumb, apply gentle pressure to the battery until it clicks into place.
  4. Sanyo Katana Eclipse X Battery Replacement: Schritt 4, Bild 1 von 1
    • Take the phone’s back casing and set it over the battery.
    • Apply gentle pressure, pushing towards the top of the phone until your hear a click.
Abschluss
Thomas Scaggs
209 Reputation
2 Anleitungen geschrieben
University of Maine, Team 1-3, Diaz Fall 2012 Mitglied von University of Maine, Team 1-3, Diaz Fall 2012
UMAINE-DIAZ-F12S1G3
5 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 14
Insgesamt: 451
